jack lackmaker Posted December 27, 2010 Share Posted December 27, 2010 what is the differance between glider set up and planes when you program the transmitter???? Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 27, 2010 Share Posted December 27, 2010 It's like a Christmas pudding - all in the mixing... Stuff like 4 (or more) aileron wings, crow braking, etc. Quote Link to comment Share on other sites More sharing options...
John Tee Posted December 27, 2010 Share Posted December 27, 2010 hI Jack I'm not a glider guider but from what Ive learnt on this forum ailerons and flaps can be set to go up as well as down to act as airbrakes and flaps. more detailed than this and I'm sure a proper glider man will put you right on the technical bits John Quote Link to comment Share on other sites More sharing options...
Ultymate Posted December 27, 2010 Share Posted December 27, 2010 The glider setup is used to give the wings more camber to generate lift or to give reflex to give more speed also crow braking or butterfly is used where usually the flaps are lowered and the ailerons are raised to slow the glider for landing Quote Link to comment Share on other sites More sharing options...
