Will this camera mount be ok?
I have just made this mount for my Gum Cam
It is designed to fit like this
It is secured on the wing mount bolts of my Stik , It weighs next to nothing, according to my kitchen scales just over an once!
There appears to be no difference in the balance of the model, will this make the model dangerous / uncontrollable to fly?
The camera stands 75mm high and 20mm wide.
Cheers guys
Phil
You're going to get an awful lot of nothing but sky unless you intend to fly inverted most of the time.
I think the results will be better if the camera is pointing backwards or if you can mount it underneath the model pointing at slightly down
