Tony Bennett Posted August 1, 2011 Author Share Posted August 1, 2011 wings nearly ready for paint. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 1, 2011 Author Share Posted August 1, 2011 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 2, 2011 Author Share Posted August 2, 2011 not much to report.finished covering the wing.started painting the fuselage.not in the mood at the mo. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 3, 2011 Author Share Posted August 3, 2011 paint and wiring next. Quote Link to comment Share on other sites More sharing options...
Steve Adams Posted August 3, 2011 Share Posted August 3, 2011 Hi Tony, As regards to the wheels,Mabe some Spats/Pants would look good? ....Just a thought anyway!! Steve Quote Link to comment Share on other sites More sharing options...
Chris Reid Posted August 4, 2011 Share Posted August 4, 2011 Hi Guys, It's good to see you having fun with Agritug. Mine is still flying very well. Its great that tissue and dope are still being used! Minor differences on the plan to my photos crop up when I do the final drawing from my rough plan and change things that didn't quite work well on the build. The undercarriage is over simple I agree, but semi scale oleos that slotted into a bit of tube at the wing crank would improve the appearance - I re-used the undercarriage from the wrecked Pogostick that provided the motor etc. An Axi 2820/10 is not an essential. I had one that I won in an RCM&E phot ocompetition. They are very pricy, but they do go well. Any brushless motor of 250-350 Watts will do. Funterceptor is a mini Agritug that flies just as well on a very basic power set up. It's a very simple build but if there are any questions I'll be happy to help if I can. Chris Reid Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted August 4, 2011 Share Posted August 4, 2011 Hi Tony, been following your blog on the Agritug, I think you have done a great job. Tissue and dope, very good choice of covering. Are you going to paint it, or do you think paint will add more weight that's not needed. Cheers FB3Edited By fly boy3 on 04/08/2011 21:41:20 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 4, 2011 Author Share Posted August 4, 2011 thanks Chris.It's been a great and simple build, just what i need after a 40 year lay off. I'm still thinking about the undercarriage, also thinking about some scaleish crop spraying equipment, should be finished very soon. FB3 it is going to be painted this weekend, then the wiring and jobs a good un. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted August 4, 2011 Share Posted August 4, 2011 Nice one Tony, hope to see the pictures of the finished article soon. CheersFB3 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 5, 2011 Author Share Posted August 5, 2011 Quote Link to comment Share on other sites More sharing options...
Bob H Posted August 5, 2011 Share Posted August 5, 2011 Hi Tony, Re the aileron control.... ( Radio Active Aileron Set ).Cannot really work out how the wire (which must be bent as it crosses the Dihedral Point on the wing actually works. Does yours do what it is supposed to do ? Cheers Bob H Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 5, 2011 Author Share Posted August 5, 2011 i found that i had to keep it as near to the dihedral point as possible, mine does work fine, just a bit fiddly to get right. Quote Link to comment Share on other sites More sharing options...
Chris Reid Posted August 6, 2011 Share Posted August 6, 2011 Hi Bob. Tony is right. You are correct in thinking that the aileron torque rod theoretically ought to angle at the dihedral joint in some way. However, I have found on several models that if you use the rod as a hinge, there is enough natural slack in the system to cope with the small angle at the dihedral joint. Don't worry about it. Chris R Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 6, 2011 Author Share Posted August 6, 2011 oooooooooooooooooooooooooi got something right.that makes a change.back to painting today. Quote Link to comment Share on other sites More sharing options...
Bob H Posted August 6, 2011 Share Posted August 6, 2011 Thank you Chris and Tony for your replies. I shall have a go. Cheers, Bob Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 6, 2011 Author Share Posted August 6, 2011 its not as hard to do as i thought, just lay it out and work methodically through the steps.i did 1 side at a time and dry assembled everything to make sure it worked first. i'm sure i posted how i did it on here.its a clever way of doing it as a) saves a servob) keeps the wing clear. Quote Link to comment Share on other sites More sharing options...
Bob H Posted August 6, 2011 Share Posted August 6, 2011 Tony Thanks again for your help. On second thoughts have decided to use two small servos, one in each wing half. Kind Regards, Bob Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 6, 2011 Author Share Posted August 6, 2011 its starting to look like something now. Quote Link to comment Share on other sites More sharing options...
Tom Wright 2 Posted August 7, 2011 Share Posted August 7, 2011 That's been amazing progress Tony nice job ..........Did you know Chris Reid was on the Frog design team ? Chris . Its realy good to know you are still in the hobby, Tom. Quote Link to comment Share on other sites More sharing options...
Chris Reid Posted August 7, 2011 Share Posted August 7, 2011 Great progress Tony. It's a real buzz for a designer to see a drawing come to life at someone else's hands. Good luck with the flying; providing you have no serious warps and the CG is in the right place, you'll find Agritug easy but fun. Thanks for the kind words Tom. I'm still in the hobby because I've been a sucker for aeroplanes small and large all my life - travel with budget airlines excepted. My time with Frog was a brief 13 months after I discovered that the head of the design department had been with the company 28 years - I couldn't wait that long. Triang Toys AKA International Model Aircraft (Frog) went bust a year later. Nothing to do with me! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 7, 2011 Author Share Posted August 7, 2011 well fingers crossed i have not incorporated any warps, don't look like it. i need easy,it has been a simple and clear to understand build so far, a testament to the designer. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 8, 2011 Author Share Posted August 8, 2011 getting on with the painting.nearly time for electrics. Quote Link to comment Share on other sites More sharing options...
Wiltshire Flyer Posted August 9, 2011 Share Posted August 9, 2011 Looking really really nice Tony!!!!! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 9, 2011 Author Share Posted August 9, 2011 the reg number is not very good, but hand painting letters with my shaky hands is not easy. Quote Link to comment Share on other sites More sharing options...
Wiltshire Flyer Posted August 9, 2011 Share Posted August 9, 2011 Posted by tony bennett on 09/08/2011 00:10:54:the reg number is not very good, but hand painting letters with my shaky hands is not easy. if i had attempted it it would have looked like a seismic graph!!!! credit to you. Quote Link to comment Share on other sites More sharing options...
