Steve W-O Posted December 30, 2011 Share Posted December 30, 2011 Quite small at 41 3/4", but should be a quicker build than the Linnet, and will give me something to do between the Linnet stages. Quicker because it comes in a box I'm going to build it exactly as the kit dictates, use all the materials as supplied.No doubt there will have to be adaptation to fit the motor.It is surprising how many bits there are to make up such a small plane. You don't notice the number of pieces when you cut them out and put together as you go. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 30, 2011 Share Posted December 30, 2011 looks good Steve, nice proportions - the plane that is Cheers Danny Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted December 30, 2011 Share Posted December 30, 2011 Hi Steve, Good choice, a mate built one last year a very nice model to build. Cheers, Chris. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted January 4, 2012 Author Share Posted January 4, 2012 Had a "thinking" break from the Linnet yesterday, so the Beguine looks like this now. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 5, 2012 Share Posted January 5, 2012 I presume that will be flying tomorrow if the wind eases then Very quick progress.. and very nice Martyn Quote Link to comment Share on other sites More sharing options...
Antiquated Posted January 5, 2012 Share Posted January 5, 2012 One thing I noticed from my plans is that the exit vent for air flow is behind one of the solid bulkheads, and so cut off from flow from the front of the plane. What sort of power system are you planning to use - I have been wondering about using an outrunner, rather than the geared motor originally specified? Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted January 5, 2012 Author Share Posted January 5, 2012 Posted by Antiquated on 05/01/2012 14:12:04: One thing I noticed from my plans is that the exit vent for air flow is behind one of the solid bulkheads, and so cut off from flow from the front of the plane. What sort of power system are you planning to use - I have been wondering about using an outrunner, rather than the geared motor originally specified? Yes, quite amusing, they mention how important the airflow past the battery is, then make a useless hole! Behind the ply floor, between the next two formers back, I intent to put some 1/16 balsa with 2 1" holes. I am definitely using brushless, it will be a bell motor, haven't out the final arrangement yet, will depend on the weight. Using a brushless motor will save at least 50g, changing the wheels will save 20g, but I will use ordinary covering film, which will cost me about 30g above the lightweight film. It should have a duration of between 30 and 55 minutes at cruise throttle. Quote Link to comment Share on other sites More sharing options...
Antiquated Posted January 5, 2012 Share Posted January 5, 2012 Thanks - what sort of all-up weight are you aiming for? Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted January 5, 2012 Author Share Posted January 5, 2012 Posted by Antiquated on 05/01/2012 17:20:56:Thanks - what sort of all-up weight are you aiming for? I'm hoping to get it in less than the recommended weight with a 1500mAh or 2200mAh lipo. That will give me the option of using a 900mAh lipo for quiet days and slow flight. Haven't weighed it as it is, so no idea of where I am yet. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted January 5, 2012 Author Share Posted January 5, 2012 It looks like I will use a 2822-14 motor, and a 9X4.7 prop.With a 2200mAh battery, that will be around the 560g max recommended, and give mixed flying of over 30min. Could use a smaller motor, as that will give vertical performance, but they usually have a higher speed, and I want to keep the bigger prop. I intend to keep the original motor mount rails and make up a ply adaptor for the motor Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted January 5, 2012 Author Share Posted January 5, 2012 If ground clearance is a problem, then I have a 2208-14, which with a 7X4 prop will give me more power than I need and longer flying times. It will only save about 15g, so it is not the first choice Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted January 8, 2012 Author Share Posted January 8, 2012 Finished the motor mount. It will sit in the original mounting rails, held in with four 3mm bolts with nylock nuts. Allows for any motor I chose, just by moving it back or forward. It has a couple of degrees of right thrust built in, and the motor mounting holes are offset to the left so that the prop shaft comes out in the middle. Edited By Steve W-O on 08/01/2012 09:49:46 Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted January 8, 2012 Share Posted January 8, 2012 I like the idea of the movable motor mount Steve, it allows so much flexibility without modifying the original built in mounts. Cheers, Chris. Quote Link to comment Share on other sites More sharing options...
Anthony Billings Posted January 23, 2012 Share Posted January 23, 2012 Hi Steve, that is brill, and so simple, I am going to pinch that idea for my S60. Tony Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted January 23, 2012 Share Posted January 23, 2012 My Beguine should arive tomorrow,thanks for the engine mount design Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted January 24, 2012 Share Posted January 24, 2012 The beguin is here,Theres a sticker on the lid that says "This kit now includes parts and instructions to fit a brushless outrunner" Just got to clear the work space before i open the lid and breath the balsa smell in. Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted February 19, 2012 Share Posted February 19, 2012 Well it's been a cold few weeks so not much going out was done,i managed to crack on with my Beguine though and finnished her today. Just got to get brave enough to launch her now lol. Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted February 19, 2012 Share Posted February 19, 2012 Looks neat Del, I'll be interested to know how it fly's. Cheers, Chris. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted February 19, 2012 Share Posted February 19, 2012 looks great, good luck with the maiden Cheers Danny Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted March 13, 2012 Share Posted March 13, 2012 Well the beguine and myself had our first ever flight together.The first hand launch went about 10 foot then hit the floor but no damage done so i gave it a firmer lob and away she went,after a few frantic oh my god i'm flying moments i settled down and flew all around the field behind my house.The landing was a bit heavy,bent a landing leg,snapped the prop and bent the motor shaft but the replacement parts will be here tomorrow ready for round 2. Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted March 14, 2012 Author Share Posted March 14, 2012 Glad it wasn't too bad, and at least it flies What was the cause of the heavy landing? Looking at it, I get the feeling that it would be easy to lose to much speed, and end up coming down in a nose down attitude, and the elevator not having any effect in levelling it Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted March 14, 2012 Share Posted March 14, 2012 The heavy landing was all down to me Steve,it was my first attempt and i lost height way too quickly and was going to fast. As soon as the posties been i'll be out on the farm to try again. Quote Link to comment Share on other sites More sharing options...
