Sandow
  • 6 months later...
Hi Craig. No one has mentioned this one so far. I can't remember now what I did.
Interestingly the cut away shows the 3/16 sq rear rib.
Quite honestly structurally it will not make much difference. The original smaller model only used 1/16 X 1/8 spars.
If you feel like changing the slot in the rib template do but if you want to use two 1/4" sq spars that is fine.
Sorry that I have not been more helpful.
hi peter
i can understand you having lack of space after all the years you have been building ect, some of it is knowing what to keep and what to get rid of cant be easy.
i have parted with so many model's and plans which i have regretted afterwards but simply didnt have the space to keep them all, thank you for the replys peter i have always been a big fan of your work.
kind regards craig
