Koen Smits Posted February 18, 2013 Share Posted February 18, 2013 After reading the artikel about the Panther autogyro, i'm going to build one. The problem how to get the parts drawn onto the wood isolved in the following manner. Some years ago i bought a Calcomp drawingboard on a garage sale. Because the drawingboard is out of the Dos era, no drivers for windows XP. Therefor i wrote a small programm in VB 2008. After scanning a part into the programm, it can be saved as a dxf file. This dxf file can be loaded in a CAD programm ( autocad, drafsign or simular). After drawing some circles and lines trough the scanned coordinates you wil get a perfect drawing. this drawing has to be saved again as dxf file. Results in The drawing in the example gets divided into two files, the middle piece and the side pieces from the mast. And prepared to use in the router control software Quote Link to comment Share on other sites More sharing options...
Koen Smits Posted February 18, 2013 Author Share Posted February 18, 2013 For the mast it's neccessary to glue some pieces of wood together After the glue is dry, clamp th woodpiece on the router table Load the prepared dxf file into the router control software and start routing Job done. and so on with the other parts. Quote Link to comment Share on other sites More sharing options...
simon burch Posted February 18, 2013 Share Posted February 18, 2013 I'd love to own a routing table of some sort.......I don't think I would ever go out !! Quote Link to comment Share on other sites More sharing options...
Olly P Posted February 19, 2013 Share Posted February 19, 2013 Lucky person! I believe that the designer of the Panther is on here - he my have Dxf's available for you?? Quote Link to comment Share on other sites More sharing options...
Koen Smits Posted February 21, 2013 Author Share Posted February 21, 2013 Olly, it would be nice if the free plan was also digital available with the digital issue and not only with the printed issue. The past 2 days did some glueing from the parts, Checking if i did not make a banana. Because the sheets are not wide enough to go around the radius in one piece, I have to divide them in two. Prerolled sheet fit on the radius, the sheet is prerolled on dogfood tins. For those people who ask, how do you get those lang tapered stringers, possible next pictures maybe of help. Take a new and straight sheet hard balse from 6mm or', pin down the sheet were you would cut the stringers from, this sheet sould be the length from the stringers. leave the sheet 3 mm + the thinnest side of the stringer over the guide sheet and ad th widest side of the stringer, 3 mm + the widest size of the stringer. adjust the guide on the table saw, including the ticknes of the saw at the width of the guide sheet + 3 mm. Now you can cut of the first stringer. adjust the guide on the table saw to cut the sheet parallel again, i.e. cut of the second stringer. repeat above, until you habe enough stringers Edited By Koen Smits on 21/02/2013 20:43:07 Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted February 21, 2013 Share Posted February 21, 2013 Koen, Now that is just lazy!!, I do like the table saw idea to cut the dummy stringers, Nice work Rich Quote Link to comment Share on other sites More sharing options...
Koen Smits Posted February 27, 2013 Author Share Posted February 27, 2013 In the last couple of days i did some working on my panther build. Making the motorcowl. This is how far i'm now. Quote Link to comment Share on other sites More sharing options...
Tentpeg Posted March 15, 2013 Share Posted March 15, 2013 Hi, you are making very fast progress! I am encouraged to start one of these, but am puzzled by a couple of things. It appears that the rudder servo is permanently built in to the fuz with no access. Do you think it possible to fit it low down in the main central bay and a throttle servo in the forward bay alongside a fuel tank? Also, can I ask what you will use for the main rotor bearing? This is another sticking point for me at the moment. If I can solve that problem, I can get started.. Keep up the good work! It's looking very smart so far. Regards, Tentpeg. Quote Link to comment Share on other sites More sharing options...
Koen Smits Posted March 15, 2013 Author Share Posted March 15, 2013 Posted by Tentpeg on 15/03/2013 16:37:45: Hi, you are making very fast progress! I am encouraged to start one of these, but am puzzled by a couple of things. It appears that the rudder servo is permanently built in to the fuz with no access. Do you think it possible to fit it low down in the main central bay and a throttle servo in the forward bay alongside a fuel tank? Also, can I ask what you will use for the main rotor bearing? This is another sticking point for me at the moment. If I can solve that problem, I can get started.. Keep up the good work! It's looking very smart so far. Regards, Tentpeg. Hi Tentpeg, I made a bay behind former #4. here i put the receiver and rudderservo. for the rest from your questions you will find the answers in de following tread. **LINK** Koen Edited By Koen Smits on 15/03/2013 21:38:26 Quote Link to comment Share on other sites More sharing options...
Kevin Howard Posted March 21, 2013 Share Posted March 21, 2013 Koen, I was also thinking of buiding a Panther. I have access to a laser cutting machine and wonder if I could have a copy of your DFX files, save me drawing them out. Regards Kevin Quote Link to comment Share on other sites More sharing options...
Koen Smits Posted March 28, 2013 Author Share Posted March 28, 2013 Posted by Kevin Howard on 21/03/2013 15:24:30: Koen, I was also thinking of buiding a Panther. I have access to a laser cutting machine and wonder if I could have a copy of your DFX files, save me drawing them out. Regards Kevin Sorry Kevin, Because of the fact, there is a copyright on the drawing and i think also on the design of the panther and i don't want to get involved into copyright questions, i can't give you the dxf-files. Regards Koen Edited By Koen Smits on 28/03/2013 14:12:53 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 28, 2013 Share Posted March 28, 2013 well done koen.......very good quality.........for my pre-rolled sheets----i soaked the balsa in warm water for 30 mins ........and tied them to carlsberg cans.......possibly the best pre-rolled balsa in the world..... ken anderson ........ne...1 pre-rolled dept... Quote Link to comment Share on other sites More sharing options...
