Dale Gibson Posted March 10, 2013 Share Posted March 10, 2013 Hi guys, My Dad built a free flight plane back around the late 60's/early70's and after an unsuccesful maiden never bothered with it anymore. Well, the plane has been in the back of his garage ever since and today I dug it out and brought it home. I am after some info on the engine which is stamped Webra 2.5 and looks like an old diesel engine. It was only run a few times and turns over with good compression......I love vintage style kits and was wondering what size plane this would be suitable for and how I should go about getting in running again? Thanks in advance for any help/advice Dale. Edited By Dale Gibson on 10/03/2013 20:24:52 Quote Link to comment Share on other sites More sharing options...
Tom Sharp Posted March 10, 2013 Share Posted March 10, 2013 It's perfect for a 'Black Magic', it's in the Aeromodeller plans range. Quote Link to comment Share on other sites More sharing options...
PatMc Posted March 10, 2013 Share Posted March 10, 2013 Dale, it's a Webra Winner. Lighter but not as powerful as a PAW 2.5cc possibly around the same output as an AM25. Here's one being bench run using a 9x4 prop. You'll need to clean it up to make sure no grit gets into it then lubricate with a few drops of light oil (e.g. 3 in 1). Depends on your locality as to where you can get fuel, either Model Technics D-1000 Easy Start or D-2000 Sports Special are probably about the easiest to obtain. Only start by hand flicking - don't be tempted to use a starter - it's too easy to bend a conrod or even crank pin & you probably won't be able to get any spares. There was a muffler made for them which you probably won't be able to get anywhere now. They are not particularly loud engines but it depends on your local site whether an unsilenced engine will be tolerated. Edited By PatMc on 10/03/2013 21:03:50 Quote Link to comment Share on other sites More sharing options...
Dale Gibson Posted March 11, 2013 Author Share Posted March 11, 2013 Thanks for the info Tom and PatMc...any ideas where I could get obtain a manual/instructions to help me with setting it up as this is all new to me.... Dale. Quote Link to comment Share on other sites More sharing options...
PatMc Posted March 11, 2013 Share Posted March 11, 2013 Dale, I doubt that you will be able to obtain the Webra instructions but I have a scanned copy of the general instructions for starting & operating the DC Quickstart range of diesels. Also a scanned article "Operating Your First Diesel" from a 1959 model aero engines book. It's not possible to post them here but if you would like a copy of either or both PM me with your email address. The DC scan is 2.5Mb, the article is only 39kb because it doesn't contain any illustrations. Quote Link to comment Share on other sites More sharing options...
Dale Gibson Posted March 11, 2013 Author Share Posted March 11, 2013 Huge thank you to PatMc for the email Very helpful indeed. Dale. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted March 14, 2013 Share Posted March 14, 2013 Hi Dale . It would also be a good idea to get a diesel user or a member of the "oily hand society " to show you how to set it up and start it . The instructions set out the basics but dont tell you what to listen for . You have to get used to the sound of a diesel as an over compressed engine could be damaged if not corrected . regards Quote Link to comment Share on other sites More sharing options...
Dale Gibson Posted March 14, 2013 Author Share Posted March 14, 2013 Thanks for the advice EG I will ask down the club when I next go Dale. Quote Link to comment Share on other sites More sharing options...
