Greg Watkiss Posted May 6, 2013 Share Posted May 6, 2013 Hello, Could someone recommened a good Cyano adhesive for EPO foam. Thanks, Greg Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted May 6, 2013 Share Posted May 6, 2013 On EPO such as Multiplex's Elapor and that used on the Durafly Vampire, i've used regular CA, with no issues. Strong Bond and no foam melting. This only works on EPO. In the past, i've also used UHU Por with great success, following the instructions using as a contact adhesive and its just as good as CA. Quote Link to comment Share on other sites More sharing options...
Pete B Posted May 6, 2013 Share Posted May 6, 2013 Any normal cyano, Greg, don't use 'foam-safe' - it does not work well on EPO. Save the 'foam-safe' for EPS, or polystyrene. Plenty of modelling brands out there such as Zap but most commercial cyano works fine. Even 'pound shop' cyano....it would seem! You can get it in various viscosities. The thicker it is, the slower it tends to bond. If you go for thin cayano, it goes really fast - you need to have the pieces joined then allow capillary action to take the thin cyano into the joint. Medium and thin cyano should cover most applications. As Reno says, UHU-POR is a good contact adhesive, too Pete Quote Link to comment Share on other sites More sharing options...
Danos Posted May 8, 2013 Share Posted May 8, 2013 Hi Gregg i use 5min epoxy bonds real good Quote Link to comment Share on other sites More sharing options...
rory mc cann Posted November 14, 2013 Share Posted November 14, 2013 just received the hobbyking radjet,,,,,,,and was wondering what glue would be best suited for this build??? Quote Link to comment Share on other sites More sharing options...
Bill_B Posted November 15, 2013 Share Posted November 15, 2013 Posted by rory mc cann on 14/11/2013 21:04:17: just received the hobbyking radjet,,,,,,,and was wondering what glue would be best suited for this build??? If it's the larger Radjet 800 then medium viscosity cyano will do the trick nicely. My preferred adhesive for all EPO type foams is Multiplex's Zacki. It might be dearer than most others, but it is very good stuff. If it's the smaller Radjet 420, then foam safe cyano or UHU Por is your only option. Quote Link to comment Share on other sites More sharing options...
Robert Putley 1 Posted November 15, 2013 Share Posted November 15, 2013 Hello, does anyone know what glue one should use on a Kyosho Minium plane? Quote Link to comment Share on other sites More sharing options...
simon barr Posted November 15, 2013 Share Posted November 15, 2013 Posted by Danos on 08/05/2013 19:30:25: Hi Gregg i use 5min epoxy bonds real good Epoxy is not recommended for EPO type foam... It may seem strong, but it will not hold under high stress. Only use cyano. Quote Link to comment Share on other sites More sharing options...
simon barr Posted November 15, 2013 Share Posted November 15, 2013 Posted by Robert Putley 1 on 15/11/2013 06:13:24: Hello, does anyone know what glue one should use on a Kyosho Minium plane? If the Minimun is depron (which I think it is), then use FOAM SAFE cyano. Normal stuff will melt it. Quote Link to comment Share on other sites More sharing options...
