Dwain Dibley. Posted May 11, 2013 Share Posted May 11, 2013 Hello there folks, I have been hard at work on a hostetler Cessna 195 from Belair . I have got quite a long way along with the fuselage so I will just do a bit of a pictoral catch up to date for you. I hope you like it. D.D. Edited By Dwain dibley on 11/05/2013 14:18:17 Edited By Dwain dibley on 11/05/2013 14:37:13 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 11, 2013 Author Share Posted May 11, 2013 Edited By Dwain dibley on 11/05/2013 14:38:48 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 11, 2013 Author Share Posted May 11, 2013 The phenolic tube is too big for the precut rib holes so I will have to open them up using the tube as a template. D.D. Edited By Dwain dibley on 11/05/2013 15:15:01 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 11, 2013 Author Share Posted May 11, 2013 Scary cut Edited By Dwain dibley on 11/05/2013 15:14:09 Edited By Dwain dibley on 11/05/2013 15:15:46 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 11, 2013 Author Share Posted May 11, 2013 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 11, 2013 Author Share Posted May 11, 2013 Getting on now with the fuz almost complete we need to add a servo tray under the hatch we built. Wing pegs. Tail wheel mount Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 11, 2013 Author Share Posted May 11, 2013 Ok. the fire wall was next, made up from two pieces of ply to 3/8". Then a ring was added from laminated 1/4" laser cut parts, these were overlapped for strength. The funny thing here was they were too big and I had to cut one down on each layer. Sanded to profile. A door, as on full size, for switch gear. Rudder hinges, I used point hinges. Firewall mocked up in position. The plan specifies 26 to 50cc. I don't know what I will fit yet, I have still to receive the cowl. I made tabs to locate the firewall, I will also make a box section to strengthen things a bit.. Before the front goes on there is a boat load I have to do on the interior, like a floor, ceiling, instruments, seating and yokes. This is what I want to achieve on the outside. A classic 30's look... Well that's the build up to date, hope you weren't bored, I'm off to Long Marston to raid the Balsa tents tomorrow. One of the reasons for the halt on the build was a need for materials, the other was I pranged my DB Auster, and was repairing her as a bit of a change from the 195. D.D. Edited By Dwain dibley on 11/05/2013 22:37:48 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 11, 2013 Share Posted May 11, 2013 Hey DD good to see the build is coming together, and what a gorgeous subjetc it will be too. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 12, 2013 Share Posted May 12, 2013 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 12, 2013 Author Share Posted May 12, 2013 Thanks Chaps.. Any of the golden era aircraft would do me, but it was a toss up between the chester Jeep, the Laird Turner, or the 195, and as I love the cessna in all her guises, the 195 it had to be. The four stroke is apealing I must say. I also have this in my Garage but it does not belong to me, I am just her guardian at the minute. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 12, 2013 Author Share Posted May 12, 2013 Mr Mulligan it is. Powered by a Tartan Twin 44cc Glow. I must confess to also liking civvies over military types. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 12, 2013 Author Share Posted May 12, 2013 My new pile of wood from the Slec tent today. D.D. Quote Link to comment Share on other sites More sharing options...
Limobob Posted May 13, 2013 Share Posted May 13, 2013 Awful lot of balsa DD. Looking forward to seeing where it all ends up! Can't be all for the Cessna surely! Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 13, 2013 Author Share Posted May 13, 2013 Posted by Limobob on 13/05/2013 05:50:05: Awful lot of balsa DD. Can't be all for the Cessna surely! I know !! But yes it is.....Everything is fully sheeted, and with a 7' fuz and a 9' span, it uses quite a bit of wood. I have decided to go with the part sheeted and rib capped version of the wing as well. !! D.D. Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 13, 2013 Share Posted May 13, 2013 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 29, 2013 Author Share Posted May 29, 2013 Well I finally got round to working on the Cessna again. I had kind of lost momentum, so I started on a bit of sheeting work. The whole of the model is sheeted, with the exception of the wings, which can be part sheeted if you so desire. I like the look of a rib capped wing so thats the way I am going. I spent a long time studying the plan, when it came to building the horizontal stabilizer, just as well because the plan had certain anomalies..One of the ribs, (S4) was too long, so before cutting I had to make sure it wasn't supposed to be too long. Also the elevator halves are tapered at both ends, which also presented a problem, in the end I decided to cut the leading edges way bigger and then plane them back...the pics will explain better. I marked all the centre points on everything and then lined them up, made sure they were square and glued them up. A lot of planing and sanding ensued. I then covered the whole lot in 1/16 sheet, they are as light as possible as they are a long way behind the C of G. D.D. Here we go. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 29, 2013 Author Share Posted May 29, 2013 A pile of bits and wood. Sheeting on the vertical stab. The errant S4 Rib. The process is repeated for a nice pair. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 24, 2014 Author Share Posted May 24, 2014 Hi Guys..... I have not touched this project for a whole year now. Mainly because I have got into cycling in a big way, and partly because we are struggling to find somewhere to fly our .60 and smaller sized models. The lack of a good field/Club being a big pain in the **s. I will continue to build, but nothing as big as this. I have therefore decide that I will part with it. It comes with.... Full size plans (2 sheets) All the balsa to finish the model. The cowl and spats. The wing tube and phenolic tube. The total cost of the whole lot was in the region of £450........The first one of you guys with £250 can take it away. Feel free to message or Email me with any questions or sensible offers. Regards D.D. Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 25, 2014 Share Posted May 25, 2014 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Limobob Posted June 11, 2014 Share Posted June 11, 2014 Such a shame to have to give it up after all your hard work. Your building skills are a joy to see and great credit to you. I hope whover buys this gem will crack on and finish it to the same standard you achieve. Maybe think again DD and put it to one side for when the flying site scene brightens up - I am certain you will regret your decision in the future. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted June 11, 2014 Author Share Posted June 11, 2014 Thanks for the kind comments guys, they are much appreciated. This kit builds into a darn fine looking model, especially if you spend time on the cockpit. I am sure I will regret it but its got to go, unless I win the lottery and can buy my own field. D.D. Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 11, 2014 Share Posted June 11, 2014 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
