Carl Muff Posted May 12, 2013 Share Posted May 12, 2013 hi all has anyone got one of these i built mine and on the run up trails the prop came off and hit the wall breaking ,so no flying till the new one comes and if its as long as my auto g blades it will be ages . i couldn,t have tighten it anymore has anyone had the same problem Quote Link to comment Share on other sites More sharing options...
Carl Muff Posted May 12, 2013 Author Share Posted May 12, 2013 found these two videos on u tube now i am scared to fly it sorry about the dual video and i sold my stuka to make room bet i live to reget it lol Edited By Carl Muff on 12/05/2013 17:45:52 Edited By Pete B - Moderator on 12/05/2013 17:50:45 Quote Link to comment Share on other sites More sharing options...
Tony Read Posted May 12, 2013 Share Posted May 12, 2013 Its a common problem. There has been a bit of chat about the Hurri on this forum here Might be some info on the prop problem. There is no doubt a fix on RGC but you have to wade through a load of rubbish to find the useful stuff. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted May 13, 2013 Share Posted May 13, 2013 Looks like one fix is to smear the motor shaft with cyno and let it harden. Gives the prop adaptor something to grip to. Maybe heat shrink might do the same job? Quote Link to comment Share on other sites More sharing options...
Carl Muff Posted May 13, 2013 Author Share Posted May 13, 2013 thats a idea will try the heat sink i did think of glue it on but then how would i get it of Quote Link to comment Share on other sites More sharing options...
Olly P Posted May 13, 2013 Share Posted May 13, 2013 Carl - if you did the glue option, put the glue on the shaft without the porp/adaptor, allow to harden, then tighten up on the hardened glue. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted May 13, 2013 Share Posted May 13, 2013 If you try the heat shrink method don't forget to protect the foam around the nose against the heat. Don't want the dreaded popcorn effect! Quote Link to comment Share on other sites More sharing options...
Masher Posted May 13, 2013 Share Posted May 13, 2013 I've flown mine a few times and have now relegated it to the corner of the workshop - it looks pretty but I don't like to fly it. I broke the prop last time out (it doesn't take much doing!) and couldn't source exact replacement so used one from GC - this involved changing the prop adaptor too because of prop thickness then spinner doesn't fit ...... one thing after another....so I got bored with it! Also, my motor was noisey from new and I would only be able to use the U/C from a hard surface - can't get it off grass so you have to do the hand launch as in the video. Probably down to my inexperience but I'll leave foamy warbirds alone for a while! Make sure you have all your faculties in form when you maiden it! Quote Link to comment Share on other sites More sharing options...
