Hornet Rider Posted April 17, 2014 Share Posted April 17, 2014 Hey sorry for the writing...my IPhone tricked me... The Text is quite a mess, but you only need the pictures, These are missing in the Excel Sheet, but would be of significant help. John, the weight method is the most accurate and is also used on real aircraft to determine the CoG. I think for the Pitts and other plains of this size it is a very comfi method. Cheers Ric Quote Link to comment Share on other sites More sharing options...
Hornet Rider Posted April 17, 2014 Share Posted April 17, 2014 Ok guys as promised, here some pictures of my build. I have made a box for my lipos, I plan to use 3pcs 2S 2500mAh. 1x RX, 1x ignition, 1x Smoker (Alternative secondary RX). Probably by now you will notice, that instead of applying the 3.5mm balsa cover in the tail, I first mounted the rudder. By now (yesterday I applied the first half of it) I know it was a mistake as it takes hell more time to add it now. Also the mounting for tanks, ignition and smoker is in place. The small tank is for the smoke system. I am using the Emcotec with integrated one way valve (needs less parts for installation). I am now going down to my dungeon (the place to build the Pitts) Cheers Ric Quote Link to comment Share on other sites More sharing options...
Herri Posted April 17, 2014 Author Share Posted April 17, 2014 Looking good Ric. I wonder if I will regret not adding smoke. 😚 Herri Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted April 17, 2014 Share Posted April 17, 2014 Thanks Herri, I got the spread sheet, which issue of RCME was the Danny Fenton CofG article? Quote Link to comment Share on other sites More sharing options...
Herri Posted April 17, 2014 Author Share Posted April 17, 2014 November 2013 Quote Link to comment Share on other sites More sharing options...
Ultymate Posted April 17, 2014 Share Posted April 17, 2014 If you guys are running smoke make sure none of your oil gets under your covering as you'll never get your covering to adhere again. I had it in a large Ultimate years ago, great spectacle for displays but for me never again Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted April 17, 2014 Share Posted April 17, 2014 Thanks, just read the article and it all seams straight forward so I'll be buying some digital kitchen scales tomorrow. Quote Link to comment Share on other sites More sharing options...
Herri Posted April 17, 2014 Author Share Posted April 17, 2014 Just make sure they go up to 5kg as I had some which only did 2kg max. Mine are from Aldi and will take 5kg. Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted April 18, 2014 Share Posted April 18, 2014 Yes I got the 5kg ones from Aldi, did you use two scales or three? I was thinking that I could use one scale for the main wheels, was the weight for the front wheels under 5kg, or do I need to use one scale for each wheel? Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted April 18, 2014 Share Posted April 18, 2014 I just looked at your spread sheet...............One scale for each wheel. thanks agian Quote Link to comment Share on other sites More sharing options...
Herri Posted April 18, 2014 Author Share Posted April 18, 2014 I only used one scale. I made up two pieces of packing, the exact height of the scales. I placed these under the two wheels which were not being weighed. Then just switch them around until you have done all 3 wheels. Hope this makes sense Quote Link to comment Share on other sites More sharing options...
Hornet Rider Posted April 18, 2014 Share Posted April 18, 2014 Hey folks just made a Little of work... Back of the plan eis ready and wires have been soldered. Also tank and Engine have been fitted. I need to work on the Gas servo linkage to the carb. Pics will follow as my IPad doesn't like the editor... Edited By Hornet Rider on 18/04/2014 18:58:52 Edited By Hornet Rider on 18/04/2014 19:01:31 Quote Link to comment Share on other sites More sharing options...
Hornet Rider Posted April 18, 2014 Share Posted April 18, 2014 OK here are the pics... Engine with the exhaust pipes. And fueling points added...hope this position will work...due to the double wall on the sides I was not sure where to put it instead. Quote Link to comment Share on other sites More sharing options...
Herri Posted April 18, 2014 Author Share Posted April 18, 2014 Nice 👍 Quote Link to comment Share on other sites More sharing options...
Herri Posted April 22, 2014 Author Share Posted April 22, 2014 Maiden Today !! Benn waiting for a few days for the wind to drop. This afternoon was much better. First flight was real easy, just a couple of notches down on the elevator trim. Had a second flight, everything ok. The photos are not that good but done with the phone. I've got a work trip on tomorrow, so it'll be a few days before I can fly again but hey, I know its all ok. Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted April 22, 2014 Share Posted April 22, 2014 Hi Herri , congratulations on a great job and a successful maiden... Jo Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted April 22, 2014 Share Posted April 22, 2014 Top job Herri....she looks superb. You should be very proud.... May all your landings be greasers & equal the number of take offs!!! Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted April 22, 2014 Share Posted April 22, 2014 Super job well done, how was the landing? Quote Link to comment Share on other sites More sharing options...
Concorde Speedbird Posted April 22, 2014 Share Posted April 22, 2014 A superb aeroplane, well done. I like it a lot. CS Quote Link to comment Share on other sites More sharing options...
Herri Posted April 22, 2014 Author Share Posted April 22, 2014 Thanks for the comments chaps. the first landing was a real greaser but the second was a bit bouncy. Quote Link to comment Share on other sites More sharing options...
Hornet Rider Posted April 22, 2014 Share Posted April 22, 2014 Herri congratulations. It is a very nice plane. How was flying? Any special behaviour? I am now even more looking forward to finish mine. cheers Ric Quote Link to comment Share on other sites More sharing options...
Rich too Posted April 23, 2014 Share Posted April 23, 2014 excellent, congrats! Rich Quote Link to comment Share on other sites More sharing options...
Herri Posted April 28, 2014 Author Share Posted April 28, 2014 Well this afternoon seemed a good one for flying, the risk of a shower but 10km wind max. The engine started perfectly. I had decided to fly around trying the higher rates (first flights were on a tad lower than on the plan) I also wanted to let the engine run with the occasional burst of full, then back to idle or low revs. To that end I had slightly upped the idle as after my last landing last week, the engine stopped. It restarted again straight away so there was no worries about it getting hot or anything. I am so scared of the engine stopping. After about 12 min, I decide to land. I came in much too fast and the idle was much too high. The pratt holding the sticks (me ) should have executed a go-around straight away but didn’t. When he realized it was going pear shaped, there was a huge bounce and he opened up missing the perimeter fence by inches (according to the observers) Luckily the engine responded perfectly and we dragged the aircraft back into the air. On downwind, I noticed something wrong with the gear. One side was not as it should be (appearing to pushed up) The landing this time was ok. Taxing back it looked as if the gear on one side was jammed. I couldn’t see what was wrong but there seemed to be no other damage. Driving home, I dreaded to open the alu panel and see what the damage was. Luckily, it was my alu panel holding the gear as the wire stopping the gear extending too far had broken (see photo) and the one leg was just trapped. The panel was a bit bent but otherwise everything seems ok. I am soooo relieved and have fitted a new wire (2 actually) and flying can recommence. Hopefully him on the sticks will have learnt his lesson. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 28, 2014 Share Posted April 28, 2014 Brave soul...keep at it Have a beer on me Quote Link to comment Share on other sites More sharing options...
