Don Fry Posted June 18, 2019 Share Posted June 18, 2019 Just back from a walk with the dogs, so my 15000 steps for the day are done. Now an advantage, or not, of a long walk is, apart from keeping an eye to see the murderous little swine do not kill things,there is not much to do, but think. And I pondered. My DX9 is a very early one, 2013 vintage. It has been in steady and continuous use since then. Is there a case to get these things serviced. It works. It is undamaged, and never dropped. It's dirty, wiped with a damp cloth only, as I am wary of any chemicals getting into contact with the gubbins. Quote Link to comment Share on other sites More sharing options...
Colin Carpenter Posted June 18, 2019 Share Posted June 18, 2019 Don. Mines nearly as old as yours and works perfectly ! No sign of pot wear in use. If it ain't broke don't fix it ! It's has as much use as all other brands of tx over last 50 years ( retirement ! ) ! Love it ! Colin Quote Link to comment Share on other sites More sharing options...
Don Fry Posted November 7, 2019 Share Posted November 7, 2019 Thicko calling. I have acquired, invested in, an EFlite Spacewaker, secondhand little indoor flier. Today I bound it to my DX9. All sorted, except, as a rudder, elevator aircraft, I am used to flying aircraft with ailerons, and using left stick (rudder) to steer it on the ground. So a take off run is a problem, as the left stick had no function. Brain is not happy with the change. I have in the past, done a mix, so the left stick, or right stick (rudder/ aileron) has the same effect. In other words I steer it on the ground, left stick, and mentally transfer the control to right stick to fly. i have set this up in the past. I can't remember how I did it. Any clues. Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 7, 2019 Share Posted November 7, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Don Fry Posted November 7, 2019 Share Posted November 7, 2019 Cheers Steve, trying to use wrong mix. Now sorted. Thicko signing off. Quote Link to comment Share on other sites More sharing options...
Trapper Posted November 28, 2019 Share Posted November 28, 2019 Ever since I last updated my DX9 the telemetry says ‘No data’ for pack voltage reports. I’ve tried various receivers and so on, without success. Has any kind person experienced/solved this? Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 28, 2019 Share Posted November 28, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Don Fry Posted February 4, 2020 Share Posted February 4, 2020 I'm installing an AR8010T receiver. It's fitted with 2 long aerials, one shorter than the other, each with 31 mm of bare wire exposed at the end. I'm almost sure, when I orientate the aerials in the installation, that it's the last 31 mm that I orientate. In other words the last 31mm is the aerial. Am I right. Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 4, 2020 Share Posted February 4, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Don Fry Posted February 4, 2020 Share Posted February 4, 2020 Thank you. Quote Link to comment Share on other sites More sharing options...
