AJ Posted January 8, 2014 Share Posted January 8, 2014 Mine is solid as well. Check your mixes, do you have anything feeding into ch32? Andrew Quote Link to comment Share on other sites More sharing options...
Jeff-C Posted January 8, 2014 Share Posted January 8, 2014 I have done nothing at all with the TX. I fired it up, and it just fluctuates. http://www.youtube.com/watch?v=xBTsPmpJRgo This is a link to it. As you can see, from zero to 100 and back. Almost like it is in a test or something, but I have no idea why it does it or what it is doing. Emailed RobotBirds about it and they seemed less than bothered. Apparently they have contacted FrSky, but that was months ago. Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 8, 2014 Share Posted January 8, 2014 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 9, 2014 Share Posted January 9, 2014 the way it's moving smoothly does look like it's in a servo test mode. There are some very active threads on Taranis in the Radio section on RCGroups wwhere it might be worth asking about your problem as the developers contribute on there, otherwise put a post on the OpenRx forum as Andrew suggested. Might be worth flashing to the latest firmware as well. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 9, 2014 Share Posted January 9, 2014 Jeff, for a channel to do that then it must have been programmed to do so, I'd have thought. Have a look to see if there is anything set in the Custom Switch screen, and also look in the Mix screen for anything referring to Ch32 I assume it only does that on one model memory? If you don't want it, I'd just clear (delete) that model memory. There is a Servo test template in the model templates. However, on mine, this seems to operate Ch15 smoothly end to end while Ch16 bangs hard from one end to the the other. Quote Link to comment Share on other sites More sharing options...
