john melia 1 Posted November 8, 2013 Share Posted November 8, 2013 Why do SC engines not throttle very well , I have a new sc52 and a new sc60 plus a sc 46 and a sc 91 and another sc52 presently installed in my spacewalker , the throttle response is pretty hesitant from idle to full throttle. Is this a problem with sc engines in general (it certainly seems to be) I use no-8 plugs , has anyone got an sc that throttles well and doesnt seem to bog down ? I've read a few reviews where this does seem to be a problem with these engines , any tips greatly appreciated Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted November 8, 2013 Author Share Posted November 8, 2013 I meant to say the two new engines ie the 52 and 60 are Asp's but they are just Sc's re-badged Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted November 8, 2013 Share Posted November 8, 2013 sounds like they are all running a shade rich on the low speed needle John, they all seem to come from the factory that way. All mine throttle fine, though the (ASP) 1.20s are a bit finicky - SC, ASP and Magnums are all identical bar the cast name on the side. OS-F plugs help. ps 'all' - 52, 65, 70, 90s and 1.20s. Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted November 8, 2013 Author Share Posted November 8, 2013 Thanks bob will have a bit twiddle tomorrow and see if I can improve em a bit Quote Link to comment Share on other sites More sharing options...
Ian Jones Posted November 8, 2013 Share Posted November 8, 2013 Haven't had this problem with any of mine but someone else I know seemed to have trouble - changed from OS 8 to OS 6 (hotter) plug and that helped. I usually use Enya No 3 in mine. Ian Quote Link to comment Share on other sites More sharing options...
flight1 Posted November 8, 2013 Share Posted November 8, 2013 Mine throttle well after they have been run in. It could be down to many things from to lean to to rich low and high needles and even over proped. i have only got the 4 stroke and have run them on 5% and a good glow plug os F very reliable Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 9, 2013 Share Posted November 9, 2013 Have a number of SC engines and find them excellant Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted November 9, 2013 Share Posted November 9, 2013 Two SC's...........91 and 52...........Both in 3D planes, Panic and Twist 40 respectively, where they get thrown around violently all the time and a reliable full throttle range is essential. The Panic with 91 needs a reliable super low idle or it won't land!!! They throttle perfectly well, do not need exotic throttle curves to get good linear action and have excellent and reliable low speed idles. They were run in as per the manual but anyway worked well straight away. I use 10% Contest, OS8, though if I have run out they have had 20% Heli fuel and run just the same. I find they need less open needles than my OS, Enya, TT and Irvine engines, around a turn and a half to a turn and threequarters on the main needle. I have never touched any other setting. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 9, 2013 Share Posted November 9, 2013 I have been using SC engines for years. never have any trouble setting them up. That includes everything from .12s to .91 four strokes. Just a case of setting the high end a tiny fraction richer than peak and then very careful adjustment of the slow running until you get that smooth pickup ffrom idle. And I use they old Taylor long reach strandard plugs, cheap and reliable but sadly no longer made. I aslo use Fox plugs as an alternative now. Quote Link to comment Share on other sites More sharing options...
GrahamC Posted November 9, 2013 Share Posted November 9, 2013 I've found model Technics 3d plug to work well in a SC52 - settled it down nicely. It's a little longer than standard. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted November 9, 2013 Share Posted November 9, 2013 I use ASPs & find then most excellent.....it can take a while to get them dialled in just so but once set I rarely touch the settings at all....not even the main needle......I even have rust on some of them.... Are you using the same fuel?? Chopping & changing fuel types is a recipe for unreliabiity as each fuel type will need tiny changes to the settings.....pretty much all fuels will work & work well in SCs....find one that you can obtain easily....spend some time setting the engine up.....then leave it alone & enjoy your flying. Just some other quick thoughts/watch points.....make sure all the casing screws are tight (backplate, head, carb etc) & also that you have no exhaust leaks (use a manifold gasket)....any such leaks will cause problems at low speed.... Quote Link to comment Share on other sites More sharing options...
Ron Harrison Posted November 9, 2013 Share Posted November 9, 2013 Use a 5% Nitro Fuel in my 46, with a JEN 4 Glow Plug. No problems Ron Quote Link to comment Share on other sites More sharing options...
Bandit Posted November 9, 2013 Share Posted November 9, 2013 I find SC to be great, just watch you don't go too lean, better to be a little rich than too lean Quote Link to comment Share on other sites More sharing options...
mike coombes Posted December 11, 2013 Share Posted December 11, 2013 Hi i am a new member and would like help please, I have a new sc .52 two stroke in a t77e that is near completion and i am desperate to find out what nitro mix to use for run in and what glow plug to use, after run in do i still use same mix and plug any help would be a great help as i have only ran nitro trucks before. many thanks morri8 Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted December 11, 2013 Author Share Posted December 11, 2013 I've just run in an sc 52 in my delta , I just used an old plug just incase the engine wore of bits of metal on the initial run up , ran it on my normal fuel 12% nitro , started off very rich , ran for 5 or 6 mins , stopped , let it cool , ran again increased throttle a bit for another 5 to 6 mins , shut off let cool, then again slightly leaner for 45 to 6mins , I continued to do this for a couple of tanks (8oz) replaced plug for a new one no8 , then keeping slightly rich maidened the delta .actually its an asp 52 but its a sc rebadged . must say this ones running great , with good throttle response . Quote Link to comment Share on other sites More sharing options...
William Morrison Posted December 21, 2013 Share Posted December 21, 2013 I use two Magnum four stroke engines and have no problems. Maggies are just SC/ASP engines marketed in the US. I;ve not had a two stroke Maggie yet. Other engines are readily available used and thus do not waste money on getting new stuff when so much used is sort of just laying around for the taking. Quote Link to comment Share on other sites More sharing options...
John Muir Posted December 21, 2013 Share Posted December 21, 2013 Hi Mike, Welcome to the forum. SC and ASP engines are set up to run on low nitro fuel so if you are buying specially get some 5% nitro with a decent oil content. I use Optifuel which is fine. Model Technics Irvine Sport or Supaglo would be fine also and there are quite a few others. If you happen to have some 10 or 12% kicking about, that would do too. I'd just make sure the oil content was kept up above 15% minimum. Plugs can be OS no8, Enya No3 or Firepower F6 or any other long reach, hottish plug. The engine won't need an awful lot of running in and you can use the same fuel and plug afterwards. HTH, John. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 22, 2013 Share Posted December 22, 2013 In the day Galaxys Garry recommended running in inthe air for better cooling Quote Link to comment Share on other sites More sharing options...
