Sunrise esc
foamidable
hi, i have a sunrise 25amp pro esc bec. i dont seem to be able to change the cut off mode using the tx stick and cant find a program card for this esc even though one is mentioned in the rather obscure instructions. can anybody help?
note i live in the uk so global postage etc. is not viable
foamidable.
Posted by Pete B - Moderator on 11/12/2013 09:28:17:
Here's a page of downloadable instructions for Sunrise ESC's - the 25A page is here.
Pete
Edited By Pete B - Moderator on 11/12/2013 09:30:01
hi pete, thanks for your post. i already have that manual and it seems cut off mode is only progammable by using the card which i cannot source.
foamidable
A lot of ESCs etc are simply badged generic ones and under the badge they're identical. I'd ask at your club or at your LMS to try a few different cards - you'll probably find another brand of card that works.
Otherwise, a new ESC is probably not much more expensive than a card. I tend to stick to one brand, so one card works on all my escs.
Cheers
Phil
Posted by Pete B - Moderator on 11/12/2013 13:04:19:
There's a suggestion in this thread on RCU that some of the Sunrise ESC's are those sold by 4-Max with a TESC reference.
The 4-Max prog card here ('Advence Pro' ) is identical to the card on the Sunrise site.
That might solve the problem....
Pete
hi, you're right looks like the same card trouble is £6.99 for the card plus £2.99 postage rip off.
Edited By Pete B - Moderator on 11/12/2013 13:10:36
Posted by foamidable on 11/12/2013 17:28:07:
Pete
just located a card on ebay that looks identical at £5.99 including postage, currently waiting on seller to verify that the picture of it is accurate portrayal.
