Jean Tardif Posted January 17, 2014 Author Share Posted January 17, 2014 Posted by Tony Bennett on 17/01/2014 18:50:36: that looks beautiful Jean. cant wait to see it all put together. Thank Tony , I put wing on is fuselage nex and take shot outside nex sunny day. Cheers Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 17, 2014 Share Posted January 17, 2014 lovely looking aircraft so far. just wow. Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted January 18, 2014 Author Share Posted January 18, 2014 Posted by Tony Bennett on 17/01/2014 20:10:48: lovely looking aircraft so far. just wow. So farso good , just bolt is wing on. Cheers Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 18, 2014 Share Posted January 18, 2014 that is so nice. wonderful. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 18, 2014 Share Posted January 18, 2014 Great work Jean. What paint do you use? That "sheen" you get is very realistic. Lots of people think military aircraft are flat matt - but usually they're not. They often have that sort of dull shine or sheen on them like you model. BEB Quote Link to comment Share on other sites More sharing options...
Willowlea Posted January 18, 2014 Share Posted January 18, 2014 Wow super speedy building there, Jean it looks stunning! Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted January 18, 2014 Author Share Posted January 18, 2014 Posted by Biggles' Elder Brother - Moderator on 18/01/2014 11:00:45: Great work Jean. What paint do you use? That "sheen" you get is very realistic. Lots of people think military aircraft are flat matt - but usually they're not. They often have that sort of dull shine or sheen on them like you model. BEB Thank BEB, I use Krylon spray paint , work pretty close fast dry ., and color match easy ., for under I also use flat spray can light blue color made from automotive mix color match store made direct from them also fast dry. Cheers Edited By Jean Tardif on 18/01/2014 18:12:25 Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted January 19, 2014 Author Share Posted January 19, 2014 Hi have to cover is push rods installation , look much better this way ., coming goog Cheers Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted January 19, 2014 Author Share Posted January 19, 2014 Nex important thing , weight and balance proceed , find the proper place to put for is twin 10 S-5000 LiPo., to get a decent CG., Cheers Quote Link to comment Share on other sites More sharing options...
james smith 13 Posted February 7, 2014 Share Posted February 7, 2014 A great looking aircraft. I have a question,the plans called for 7.5 degrees of incidence in the wing.What incidence did you use,and what incidence if any in the engine nacells thank you james smith Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 13, 2014 Author Share Posted February 13, 2014 Posted by james smith 13 on 07/02/2014 20:37:59: A great looking aircraft. I have a question,the plans called for 7.5 degrees of incidence in the wing.What incidence did you use,and what incidence if any in the engine nacells thank you james smith Hi james , I did not use that mutch of plan incidence ,I use a bit less like 5 degreesby 2 degrees, same for the nacelle ,. I did not measure yet , I will check later with incidence meter an I let you know., outside today foe a fews shots . Cheers Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 13, 2014 Author Share Posted February 13, 2014 Posted by Jean Tardif on 13/02/2014 00:56:48: Posted by james smith 13 on 07/02/2014 20:37:59: A great looking aircraft. I have a question,the plans called for 7.5 degrees of incidence in the wing.What incidence did you use,and what incidence if any in the engine nacells thank you james smith Hi james , I did not use that mutch of plan incidence ,I use more like like 5 degrees, same for the nacelle ,. I did not measure yet , I will check later with incidence meter an I let you know., outside today for a fews shots . Cheers Edited By Jean Tardif on 13/02/2014 00:59:40 Edited By Jean Tardif on 13/02/2014 01:00:23 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 13, 2014 Share Posted February 13, 2014 wow that sure is a lovely looking model. i bet that will fly really well. Quote Link to comment Share on other sites More sharing options...
Kelly Posted February 13, 2014 Share Posted February 13, 2014 Very nice Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 13, 2014 Author Share Posted February 13, 2014 Thank Guys, with is long sleek fuselage and with emplacement the batteries packs, look pretty good ,for carry is load almost right under is is wing CG mark, Cheers Edited By Jean Tardif on 13/02/2014 17:39:24 Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 13, 2014 Author Share Posted February 13, 2014 Hello ,video test, I did one test pull with is Aeronaut Turbo 3000 110 mm, with 10S-5000 LiPo, lok pretty good with 5kg average pull to 5.4 kg max, with 85 amps and 3,000 watts ,. so 10 kg for take off it will go,Cheers**LINK** Edited By Jean Tardif on 13/02/2014 17:48:39 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted February 13, 2014 Share Posted February 13, 2014 Can't see any problems with that! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 13, 2014 Share Posted February 13, 2014 that edf even sounds nice, very turbine like. Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 14, 2014 Author Share Posted February 14, 2014 Posted by Jean Tardif on 13/02/2014 00:56:48: Posted by james smith 13 on 07/02/2014 20:37:59: A great looking aircraft. I have a question,the plans called for 7.5 degrees of incidence in the wing.What incidence did you use,and what incidence if any in the engine nacells thank you james smith Hi james , I did not use that mutch of plan incidence ,I use a bit less like 5 degrees same for the engine nacells ,. I did not measure yet , I will check later with incidence meter an I let you know., outside today foe a fews shots . Cheers There the incidence meter , 6 degrees positive . Quote Link to comment Share on other sites More sharing options...
Vicente Bonet Posted February 14, 2014 Share Posted February 14, 2014 Congratulations for your impressive model. I constructed one of these on 2006, I used two 68 mm Minifan from Wemotec, and 10 elements Nimh on each, The plans where made by my own and they were not so acurate like yours, flying weight was nearly 4,5 kg and wing span 1850 mm. With the years I changed to Li-pos and I mounted a plastic retracts, Here is a video of one of the firsts flights. http://www.youtube.com/watch?v=-AsWEktZfC8 I hope you enjoy. Please push push push! on your model. very nice job. Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 14, 2014 Author Share Posted February 14, 2014 Posted by Vicente Bonet on 14/02/2014 08:09:11: Congratulations for your impressive model. I constructed one of these on 2006, I used two 68 mm Minifan from Wemotec, and 10 elements Nimh on each, The plans where made by my own and they were not so acurate like yours, flying weight was nearly 4,5 kg and wing span 1850 mm. With the years I changed to Li-pos and I mounted a plastic retracts, Here is a video of one of the firsts flights. http://www.youtube.com/watch?v=-AsWEktZfC8 I hope you enjoy. Please push push push! on your model. very nice job. Thank you Vincent your Arado look verry nice also ,good flight demonstration there, plenty of power, I realy like your accuracy spot landing on is short field for a jet plane, Bravo. Edited By Jean Tardif on 14/02/2014 20:18:09 Edited By Jean Tardif on 14/02/2014 20:20:36 Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 15, 2014 Author Share Posted February 15, 2014 Hello , The weigth and balance done , empty weight 10.3 kg, twin 10 LiPo packs batteries 2.9 kg, for total ready to go 13.2 kg. the CG line just perfect ,.almost the same place with the batteries or with-out the batteries,. just a little back mouvement only by .5 inch., that verry good news. Cheers Edited By Jean Tardif on 15/02/2014 05:57:41 Quote Link to comment Share on other sites More sharing options...
Jean Tardif Posted February 25, 2014 Author Share Posted February 25, 2014 Hello I did one test with full blast engines, I have 10.4 kg on scale , look good , Cheers**LINK** **LINK** Quote Link to comment Share on other sites More sharing options...
Casa da Balsa Posted April 16, 2015 Share Posted April 16, 2015 CB Digital Plans esteve aqui. Quote Link to comment Share on other sites More sharing options...
