john stones 1 - Moderator Posted January 14, 2014 Share Posted January 14, 2014 in terms of reliability, which brand of motor, esc, and lipo would you recommend Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted January 14, 2014 Share Posted January 14, 2014 Wow, I think you'll get as many different opinions here as there are different manufacturers! Most of my motors are AXI, which I think are regarded as "quite good". They've certainly served me without any problems for must be 10 years now. The only motor I've had any problem with is Hyperion, the shaft of which seems to be made out of chocolate, or some such material -- I've bent two with simple nose-overs on landing, which did no other damage to the model. As for ESCs, I've got quite a few Jetis (recommended by AXI motors), and a few HobbyWing, both of which have served me well. The only problem ones I've had are Align (they started stuttering the motor after a couple of years), and Hyperion and Graupner (they both wouldn't sync with the motors, which were the same brand). I've been flying with LiPos for seven years now and, apart from wrecking a few in crashes, they're all running fine, though some are showing signs of high IR (they won't deliver high amps any more). The brands in question are Thunder Power and Align, though recently I've bought a few Gens Ace. To a certain extent you'll get what you pay for. If they're too cheap, you'll have to replace them regularly. That's probably acceptable with LiPos, but you don't want an ESC (and BEC) to fail on you during a flight. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 14, 2014 Author Share Posted January 14, 2014 cheers Alan yes its one of those questions learnt something already though Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted March 15, 2014 Share Posted March 15, 2014 Since nobody else has chipped in, I can say that from reading other forums I see that Scorpion motors are very popular at the less-expensive end of the market, though you do have to grease/oil the bearings quite regularly (never done that with my AXIs), and Turnigy batteries too. But this is not a "recommendation", for I haven't personally used either of them Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 15, 2014 Author Share Posted March 15, 2014 thanks Alan im giving Turnigy a go motor, esc, lipo Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 15, 2014 Author Share Posted March 15, 2014 talking of which I have a Turnigy 2826/6..2200kv motor,40 esc,2200 mah lipo it says a 7x3 prop have not got wattmeter yet(in post) motors 342 watt, this prop sound correct? Quote Link to comment Share on other sites More sharing options...
Pete B Posted March 15, 2014 Share Posted March 15, 2014 Depends on whether you are using a 2S or 3S Li-Po, John. The spec recommends 7x4 for 2S, 5x5 on 3S. What's the AUW of the model? That will dictate the wattage you'll need. Pete Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 15, 2014 Author Share Posted March 15, 2014 that's odd its different to paperwork that came with it its 24 oz pushy cat 3s lipo, is 2200 lipo big enough? Quote Link to comment Share on other sites More sharing options...
Pete B Posted March 15, 2014 Share Posted March 15, 2014 Physically, that's plenty big enough weight-wise for a 24oz PCF - that seems to be the norm in the Mass Build threads. At 1.5lb AUW, 300W will give you 150W/lb, which should be plenty and a bit - 250W seems to give good performance looking at the PCF threads.... I'll move this thread over to the Mass Build section as it's specifically about the PCF and the guys building them are the best to advise on the powertrain..... Pete Quote Link to comment Share on other sites More sharing options...
