frsky taranis nightmare please help
Matt How
hi all
purchased the taranis a while ago to use it for gliding, however
i cannot get the zadig usb driver to work on my pc?
the taranis will not connect via usb
i cannot find the companion 9x which relates to the taranis anywhere and to top it off i have managed to wipe the sounds and pictures from the sd card.
if there is anyone who can help me i would be very pleasd to hear from them.
very frustrated matt
I suffered this problem for days before being told by one of the developers that you only need zadig to download updates/upgrades of which there are none yet so forget it. The developers are aware of these problems and several are working on fixes that don't involve zadig.
Further to the above are you sure you wiped sounds and pictures from the SD card? Did you download them initially?
Stick with it, I found it easier to work directly from the transmitter than try to use Companion. If you do use companion remember to set preferences forTaranis. Kevin.
Posted by kevin lane on 15/03/2014 00:12:11:
there have been upgraded firmware releases, the most recent that I'm aware of being v2940, and the SDcard comes with soundfiles, the manual etc. pre-loaded, or at least mine did!
Edited By Bob Cotsford on 15/03/2014 09:06:11
