Matt How Posted March 14, 2014 Share Posted March 14, 2014 hi all purchased the taranis a while ago to use it for gliding, however i cannot get the zadig usb driver to work on my pc? the taranis will not connect via usb i cannot find the companion 9x which relates to the taranis anywhere and to top it off i have managed to wipe the sounds and pictures from the sd card. if there is anyone who can help me i would be very pleasd to hear from them. very frustrated matt Quote Link to comment Share on other sites More sharing options...
Andy Butler Posted March 14, 2014 Share Posted March 14, 2014 Matt, Have a look on here, this is not uncommon. There is also a 1500 page thread here that you can search, it comes up quite often. Let us know if you get it sorted - or not. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted March 14, 2014 Share Posted March 14, 2014 you can download the sdcard contents from the FrSky website Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 14, 2014 Share Posted March 14, 2014 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted March 14, 2014 Share Posted March 14, 2014 Hi Matt To connect the Tx to companion9X software for programming planes etc, you must have the Tx switched on and any warnings cleared before you connect the cable. If you plug the cable in before turning Tx on, you go into firmware update mode. Not sure if this is your problem? But it's worth a mention here. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted March 14, 2014 Share Posted March 14, 2014 Try here for the companion9x software. Quote Link to comment Share on other sites More sharing options...
RichFR Posted March 14, 2014 Share Posted March 14, 2014 I had the same problem have a look at this video (and all of Scott's others full of useful information) Zagdiag sorted it for me Quote Link to comment Share on other sites More sharing options...
C Norton Posted March 14, 2014 Share Posted March 14, 2014 Have a look at post #3242 on this page. Might be helpful. Chris Quote Link to comment Share on other sites More sharing options...
kevin lane Posted March 15, 2014 Share Posted March 15, 2014 I suffered this problem for days before being told by one of the developers that you only need zadig to download updates/upgrades of which there are none yet so forget it. The developers are aware of these problems and several are working on fixes that don't involve zadig. Quote Link to comment Share on other sites More sharing options...
kevin lane Posted March 15, 2014 Share Posted March 15, 2014 Further to the above are you sure you wiped sounds and pictures from the SD card? Did you download them initially? Stick with it, I found it easier to work directly from the transmitter than try to use Companion. If you do use companion remember to set preferences forTaranis. Kevin. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted March 15, 2014 Share Posted March 15, 2014 Posted by kevin lane on 15/03/2014 00:12:11: only need zadig to download updates/upgrades of which there are none yet so forget it. there have been upgraded firmware releases, the most recent that I'm aware of being v2940, and the SDcard comes with soundfiles, the manual etc. pre-loaded, or at least mine did! Edited By Bob Cotsford on 15/03/2014 09:06:11 Quote Link to comment Share on other sites More sharing options...
