Robin Kearney Posted April 10, 2008 Share Posted April 10, 2008 Hi there, I wonder if somebody could answer a little question for me! I have a 8 cell NiMH pack 1300 mAh, I normally charge it at home using the mains, however my charger does have a cigarette lighter adapter which I've never used. Is it wise to charge it from my car? If so what sort of amps should I be dialing in?r. Quote Link to comment Share on other sites More sharing options...
David Parry Posted April 10, 2008 Share Posted April 10, 2008 Hi Robin,If I am right you should be able to us the same as you do on the mains, all you are doing is using your car battery for power instead, your charger will have a transformer in it governing the power so even when you are on the mains it is probably still only using 12v Quote Link to comment Share on other sites More sharing options...
Alan B Posted April 10, 2008 Share Posted April 10, 2008 Hi RobinIve had a couple of the car cigarette lighter chargers. They have worked fine with no problems. They normally charge at about 500 mAh for that size of pack. Usually the chargers supplied with RTF models tend to take about 2 to 3 hours to charge a NiMH pack. Al Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 10, 2008 Share Posted April 10, 2008 If youm mean what charging current you should set, then it depends on the battery. Some packs are happy to be "fast charged" at anything up to 1C or even more....but many are best left on slow ( 1/10th C or so )Whichever you do, it is wise to leave the engine runningas long term use could mean a jump start to get going again Quote Link to comment Share on other sites More sharing options...
Robin Kearney Posted April 10, 2008 Author Share Posted April 10, 2008 thanks for all the quick replies, just in time before I go on holiday tomorrow I normally charge that pack at 2.6 amps for 30 mins at home, is that likely to stress the car too much or should I drop the current a bit? I'm probably only going to get a chance for a couple of charges due to other commitments Thanks again! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 10, 2008 Share Posted April 10, 2008 Should be fine.... but heed the warning about flat batteries ( car ones I mean ) Quote Link to comment Share on other sites More sharing options...
Alan B Posted April 10, 2008 Share Posted April 10, 2008 If its of any use to you or anybody else for that matter. I dont tend to use the car cigarette lighter. I use one of those Car Power stations. As for the usual jump leads/compressor/lights it also has 3 cigarette lighter sockets. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 10, 2008 Share Posted April 10, 2008 Yeh they are great...Maplins had em not long ago on special price. You can usually find them in your local staurday market quite cheaply Quote Link to comment Share on other sites More sharing options...
YakMad Posted April 11, 2008 Share Posted April 11, 2008 Those Car Power stations usually contain a 12 volt 18 amp/hr motorcycle battery, if you can get one cheap, strip the battery out as its pointless to lug the Power station around when you only need the battery. (It's a cheap way of getting the battery as when I last checked the battery on it's own was about twice the price of a cheap Car Power station) Quote Link to comment Share on other sites More sharing options...
Alan B Posted April 11, 2008 Share Posted April 11, 2008 Thats not a bad idea Yakmad! Didn't think of that one! I have one that has a knackered compressor and a dodgy jump lead (as I reversed over it ! ) So its been lying redundant - One extra flight box battery coming up!!!Cheers Al Quote Link to comment Share on other sites More sharing options...
iawnski Posted April 11, 2008 Share Posted April 11, 2008 hi guys ive got a fag lighter in the back of my van that i installed saves me going round the front and haveing to put the keys into ignition every time i want to use iit /i run it from the light in the back hard wired does the job great/ Quote Link to comment Share on other sites More sharing options...
birdy Posted April 11, 2008 Share Posted April 11, 2008 In essence its the same as using a 12v battery in your flight box, just the electricerty has to go through the car first... Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 11, 2008 Share Posted April 11, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Kelly Posted April 12, 2008 Share Posted April 12, 2008 Aldi are selling those Car Power Stations now for £24.99 (I think). Quote Link to comment Share on other sites More sharing options...
Helidel Posted April 12, 2008 Share Posted April 12, 2008 Have checked my cig lighter output, the fuse is 20A and the lighter takes 6A. The one at the back is the same but due to the long lead length is only fused at 5A. I charge my Lipos direct from the battery, (but off the car of course) and at a 5A drain for an hour has almost no effect on the battery. but my car is newish Quote Link to comment Share on other sites More sharing options...
Robin Kearney Posted April 14, 2008 Author Share Posted April 14, 2008 Thanks for all the advice, I charged my pack up a couple of times this weekend at 2.6A from the lighter output, all went well! Quote Link to comment Share on other sites More sharing options...
