ericrw Posted April 3, 2014 Share Posted April 3, 2014 does anyone know the wattage of a Turnigy G25 870kv motor please. Quote Link to comment Share on other sites More sharing options...
David Tweddle Posted April 3, 2014 Share Posted April 3, 2014 Try here Eric. David Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted April 3, 2014 Share Posted April 3, 2014 Hi Eric ,**LINK** Cheers Jo p.s. I was late for 2 seconds...sorry...because the people from Kent are always faster .. Edited By Josip Vrandecic -Mes on 03/04/2014 13:17:42 Edited By Josip Vrandecic -Mes on 03/04/2014 13:21:01 Edited By Josip Vrandecic -Mes on 03/04/2014 13:26:08 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 3, 2014 Share Posted April 3, 2014 The electrons have a shorter distance to travel Jo! BEB Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 3, 2014 Author Share Posted April 3, 2014 Do I take it that power equals wattage ? Which would mean that it is 470 wattage. Thanks. Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 3, 2014 Author Share Posted April 3, 2014 I was hoping to use this motor in my Dawn Flyer build but the recommended wattage for the model is only 300w. Or is it possible to use a 470w ? Quote Link to comment Share on other sites More sharing options...
eflightray Posted April 3, 2014 Share Posted April 3, 2014 Posted by ericrw on 03/04/2014 13:44:55: I was hoping to use this motor in my Dawn Flyer build but the recommended wattage for the model is only 300w. Or is it possible to use a 470w ? The 'wattage' actually used will depend on what pack voltage, and what propeller you use. Watts = volts x amps. Amps, depends on the load on the motor, i.e. the prop size. One of the first 'tools' worth getting is a wattmeter. Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 3, 2014 Author Share Posted April 3, 2014 I appreciate that the prop and esc would have to be acceptable to the 470w motor but would the increase from the recommended 300w to 470w, be acceptable to the Dawn Flyer. I`m afraid my understanding of electric is very basic and I appreciate the help I get from Forumites. Quote Link to comment Share on other sites More sharing options...
eflightray Posted April 3, 2014 Share Posted April 3, 2014 Assuming you're also an IC engine flier. It's no different really from sticking a 60 in a model meant for a 40, (and don't all IC fliers do that), it has the potential to go faster, but doesn't have to, depending on the throttle. The only other consideration is the same for the IC set-up, if it's heavier will it upset the CG. If it fits, go with it. Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 3, 2014 Author Share Posted April 3, 2014 thanks ! I`ve just had a look at your Drag racing days, very interesting !! Quote Link to comment Share on other sites More sharing options...
eflightray Posted April 3, 2014 Share Posted April 3, 2014 Just looked up the Dawn Flyer, a 48" span early monoplane, open rear frame. The Turnigy is a bit of an over-kill, but then she should cruise round nicely on low throttle. Maybe something like a 12 x 6 on 3s Lipo. Quote Link to comment Share on other sites More sharing options...
eflightray Posted April 3, 2014 Share Posted April 3, 2014 Posted by ericrw on 03/04/2014 14:40:08: thanks ! I`ve just had a look at your Drag racing days, very interesting !! That was a looooong time ago, then I got married. Quote Link to comment Share on other sites More sharing options...
Toni Reynaud Posted April 3, 2014 Share Posted April 3, 2014 Put the big motor in. The 470 watt statement means only that it is capable of handling 470 watts. If you put a smaller prop onto it, you will find it pulls less power. This means that you can choose a prop so that the motor will only pull 300 watts. However, if you put a bigger prop on and static tests with the aforementioned wattmeter shows that it pulls 470 (or 450 or even 500) watts, just fly at less power (part throttle). This is what is meant by choosing a prop to suit the plane/motor/esc combination. Another vote for getting a wattmeter - leccy fliers can't really do without unless building strictly in all respects to a proven design specification which includes motor, propellor, ESC and battery specification. Vary any one of these and the wattmeter becomes your very useful friend. Edited By Toni Reynaud on 03/04/2014 14:45:04 Quote Link to comment Share on other sites More sharing options...
David Tweddle Posted April 3, 2014 Share Posted April 3, 2014 Posted by Josip Vrandecic -Mes on 03/04/2014 13:15:58: Hi Eric ,**LINK** Cheers Jo p.s. I was late for 2 seconds...sorry...because the people from Kent are always faster .. Wrong there, I just typed it right first time Josip, for a change David Quote Link to comment Share on other sites More sharing options...
iqon Posted May 20, 2014 Share Posted May 20, 2014 is this motor suitable for hobbyking slick with a 60amp speed controller and yes i will be buying a watt meter dont ask me anything technical ive no idea when it comes to elec so if you have a better suggestion on a budget set up please feel free but please dont confuse me....this will be my first elec plane.Thanks Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 20, 2014 Share Posted May 20, 2014 Have a look at the G32 Iqon Its rated for sports models within the weight range for the Slick, I am a numptie though John Quote Link to comment Share on other sites More sharing options...
Ben B Posted May 20, 2014 Share Posted May 20, 2014 Which one there are more than one? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 20, 2014 Share Posted May 20, 2014 Ben 770 kv , I said I wasn't very good John Quote Link to comment Share on other sites More sharing options...
