Phil Claridge Posted November 5, 2014 Share Posted November 5, 2014 just used poly-c top stick some ribbon union jacks on a foamie glider,and wondered if anyone had tried mixing poly- c with emulsion paint so as to applcolour and varnish together regards phil Quote Link to comment Share on other sites More sharing options...
GONZO Posted November 5, 2014 Share Posted November 5, 2014 Have you tried food colouring from your local supermarket? Used in wing skining when using Copydex contact adhesive(water based latex). Its used to give the glue a slight colour so that you can tell where you've applied it and to ensure a uniform thickness. Not tried it but I don' see why a more concentrated mix with Pol-C would not work. Give a small sample a try and let us know. Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted November 5, 2014 Author Share Posted November 5, 2014 forgot about food colouring, will get some tomorrow and a tester pot of emulsion, and see what happens regards phil Quote Link to comment Share on other sites More sharing options...
PatMc Posted November 5, 2014 Share Posted November 5, 2014 Phil, you can get tubes of colour pigments for emulsion paint & it's possible that artists acrylic might work. The trouble with emulsion tester pots is that they are generaly quite drab compared with the colours normaly applied to models. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted November 5, 2014 Share Posted November 5, 2014 If the emulsion works, you can get pretty well any colour matched in B&Q, pant a sample with the colour you want, typically a humbrol colour then take it in, they scan it and mix it... you have to buy a litre though Quote Link to comment Share on other sites More sharing options...
Plummet Posted November 5, 2014 Share Posted November 5, 2014 Posted by Phil Claridge on 05/11/2014 17:24:14: forgot about food colouring, will get some tomorrow and a tester pot of emulsion, and see what happens regards phil Choose your colours carefully. Some of them are supposed to result on over-sensitivity and hyperactivity. Plummet Quote Link to comment Share on other sites More sharing options...
Terry Walters Posted November 6, 2014 Share Posted November 6, 2014 Phil - I haven't used it for actually painting onto an aeroplane but I did experiment with Poly C and cheap artists acrylics and it worked really well. Terry Quote Link to comment Share on other sites More sharing options...
Ben B Posted November 6, 2014 Share Posted November 6, 2014 I would be tempted to try the pigments used to colour fibre glass gel coat. Very powerful pigments- a little goes a long way and available in a full range of colours. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted November 6, 2014 Share Posted November 6, 2014 acrylic paints mixed in the poly-c will give a tinted effect like using clear dope on coloured tissue for those who can remember that far back. I tried it on the Eros with glass cloth and it worked well except that every change in wood grain or density shows through as a different shade. Quote Link to comment Share on other sites More sharing options...
