Jack Banner Posted November 30, 2014 Share Posted November 30, 2014 Hi, I am trying to change the head assembly (pn 61103f) on an ASP61FS. This involves removing 2 c-clips holding valves into the old head. I have managed to remove c-clips before using a small flat screwdriver but am having no luck with these as the clips are recessed slightly. I really wanted some c-clip pliers but have struggled to find any that specify (in a way I can understand!) the sizing so I can be sure they will fit. I did find these but cant be sure they are delicate enough: **LINK** Has anyone succeeded in doing this with a screwdriver or does anyone know where I can buy a set of pliers, preferably with interchangeable heads, that will work for RC engine / motor sized clips? all suggestions appreciated. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted November 30, 2014 Share Posted November 30, 2014 Jack You probably don't need special tooling to sort this out. I've worked on Saito, OS, SC and ASP 4 strokes of various sizes without needing C clip pliers. The C-clips are indeed recessed into collets as you say. You just need to push the collet down the valve stem (and compress the valve spring) and the c-clip will then be totally exposed and in my experience can just be pushed off with finger pressure. All it takes is a bit of manual dexterity and be sure to do it all inside a clear plastic bag (I use freezer bags) so you can see what you are doing but not lose any parts if a tiny clip or collet pings off... Quote Link to comment Share on other sites More sharing options...
Shaunie Posted November 30, 2014 Share Posted November 30, 2014 +1 For the working in a bag trick, I've even used it for motorcycle handlebar switchgear. Sounds like you need a miniature valve spring compressor, I suspect you could make one out of some plywood and a couple of long woodscrews. Shaunie. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted November 30, 2014 Share Posted November 30, 2014 Usually the tips of 1 finger off each and are enough for me to compress the spring and push down the collet. Then I use another finger to push off the clip. Cheap and quick! Quote Link to comment Share on other sites More sharing options...
Jon H Posted November 30, 2014 Share Posted November 30, 2014 What you will likely find is that the collets (not c clips as the asp's have collets...well all mine always have) have worn in the collet retainer and that's why they appear to be recessed. You can either buy new ones, or sit the head on something so the valve cant move down and get a socket (from a socket set) that's just small enough to not fit over the collet retainer. Push down hard to free everything then slowly release. Once the 'seal' is broken it should come apart more easily Edited By Jon Harper on 30/11/2014 23:08:20 Quote Link to comment Share on other sites More sharing options...
Caveman Posted November 30, 2014 Share Posted November 30, 2014 Jack, good video of the disassembly of an OS 52FS as below. The ASP engines are the same. He clearly shows the removal of the C clips, and in the reassembly videos the replacement of same. **LINK** GDB Quote Link to comment Share on other sites More sharing options...
Jon H Posted December 1, 2014 Share Posted December 1, 2014 Im surprised to see that. My OS52 has proper collets Quote Link to comment Share on other sites More sharing options...
gangster Posted December 1, 2014 Share Posted December 1, 2014 Sparks. Is that Leccy Wot (watt) built from the standard wot 4 kit also anyone electrified an Acro wot? Quote Link to comment Share on other sites More sharing options...
Jack Banner Posted December 1, 2014 Author Share Posted December 1, 2014 Thanks for the assistance guys. It hadn't occurred to me to compress the valve spring in order to free it all up. I will watch that video and give this a go again tonight. Quote Link to comment Share on other sites More sharing options...
Jack Banner Posted December 1, 2014 Author Share Posted December 1, 2014 Hah! Just watched the video, he makes that look very easy indeed I will be doing it inside a plastic bag for certain. Quote Link to comment Share on other sites More sharing options...
Jack Banner Posted December 18, 2014 Author Share Posted December 18, 2014 Just to say thanks again guys, I got these off OK and now just need to adjust the tappets. Quote Link to comment Share on other sites More sharing options...
