Eifion Herbert Posted April 17, 2015 Share Posted April 17, 2015 Hi, Has anyone else experienced the following issue with their Taranises (Taranai? Taranum?) I have a voice annoucement set to say "low rates" "middle rates" or "high rates" when the switch is in the appropriate position. I also have a timer on the throttle that announces each minute of the countdown. Was flying the Wot4 today for the first time in months and months (been learning full size gliding) - also the first time since upgrading to the 2.0.15 firmware. My 8 minute countdown timer annouced at 7 minutes, then at 6 minutes left it said "six" rather than "six minutes" and it said nothing else for the rest of the flight. Moving the rate switch didn't trigger the announcement. Switch Tx off and on, and voice is working again. Again next flight it's OK for the first minute, doesn't say anything after "six". So on the way home I left the Tx on in the car with the timer counting down. I got announcement at 7, 6, 5, 4, 3 and 2 minutes. Nothing at 1 minute, 30 seconds etc, though it did beep when the timer was up, but I think the beep is a different function to the voice announcements. So what it looks like to me is that there's some kind of issue where it will only do a certain amount of voice announcements per flight. While flying I would be switching between rates, whereas when I let it run in the car on the way back I wasn't, so it didn't "use up" it's quota of voice till later. Bizarre. And a bit worrying as if it is silent I won't be getting the RSSI warnings either. Quote Link to comment Share on other sites More sharing options...
Richard Norman Posted April 17, 2015 Share Posted April 17, 2015 Hi, I'm using 2.0.15 variant 216 and have not seen that behaviour. I don't have it calling minutes but do have it calling rate changes, U/C up and down etc. so it does a fair bit of 'talking' each flight! Hope you can identify the problem. Richard Quote Link to comment Share on other sites More sharing options...
John Privett Posted April 17, 2015 Share Posted April 17, 2015 Not something I've encountered either. I'm on 2.0.15 and have the timer 'speaking' the minutes, plus mAh consumed spoken every 500mAh, and flight-pack battery voltage on demand via one of the switches. Quote Link to comment Share on other sites More sharing options...
Eifion Herbert Posted April 17, 2015 Author Share Posted April 17, 2015 Hmm maybe I'll try reflashing it, or maybe a different SD card. Perhaps its just sulking as I haven't flown for ages and won't talk to me Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 17, 2015 Share Posted April 17, 2015 Posted by Eifion Herbert on 17/04/2015 21:40:57: Hmm maybe I'll try reflashing it, or maybe a different SD card. Perhaps its just sulking as I haven't flown for ages and won't talk to me Is it something you've said Quote Link to comment Share on other sites More sharing options...
andyh Posted April 18, 2015 Share Posted April 18, 2015 Posted by Eifion Herbert on 17/04/2015 21:40:57: Hmm maybe I'll try reflashing it, or maybe a different SD card. Perhaps its just sulking as I haven't flown for ages and won't talk to me I've had this issue - formatting & re-flashing the SD card seems to have done the trick for me Quote Link to comment Share on other sites More sharing options...
