CJD Posted August 20, 2015 Share Posted August 20, 2015 Just purchased the above motor for the Zlin 50 from our friends in China,can anyone recommend a suitable prop. Colin Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 20, 2015 Share Posted August 20, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
CJD Posted August 20, 2015 Author Share Posted August 20, 2015 Hi Percy. Propose to use 5 cells. Wing span 1612mm Fus length 1405mm Flying weight 2350g Wing area 46.4DM 70 class power system Colin Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 20, 2015 Share Posted August 20, 2015 Is it this one CJD ? Quote Link to comment Share on other sites More sharing options...
iqon Posted August 20, 2015 Share Posted August 20, 2015 look on ecalc, as far as i know it will fly it...... Quote Link to comment Share on other sites More sharing options...
CJD Posted August 20, 2015 Author Share Posted August 20, 2015 John. Yes that's the one, before bought it I contacted one of HK product specialists who recommended it Cheers Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 20, 2015 Share Posted August 20, 2015 I use them myself they're very good, I shall have to let someone else advise you with prop selection it's not my strong point. John Quote Link to comment Share on other sites More sharing options...
iqon Posted August 21, 2015 Share Posted August 21, 2015 If it was me - 17 x 10 APC elec....should give 232 w/lb on the weight you gave.......but this is only a recommendation....... dont blame me blame ecalc.....with a 80+ESC....I have used a 420kv motor on 5s.......was a emax.....it fell apart...I now use 580kv from HK..... Quote Link to comment Share on other sites More sharing options...
MattyB Posted August 21, 2015 Share Posted August 21, 2015 Posted by john stones 1 on 20/08/2015 21:48:38: Is it this one CJD ? If you look at the bottom of John's link you'll see some reviews that give working setups for this motor; check them on eCalc or a similar online calculator, but they should be a decent starting point. Personally at this size I would be going for a 6S packs rather than 5S because it is more efficient (higher voltage means reduced I2R losses). An additional benefit is that 3S packs of smaller capacity that you probably already have can be ganged together in series and parallel to power the beast at reduced outlay. Edited By MattyB on 21/08/2015 00:46:00 Quote Link to comment Share on other sites More sharing options...
MattyB Posted August 21, 2015 Share Posted August 21, 2015 More good suggestions on the Int'l warehouse listing for your motor - this sounds a well matched combo for a model such as yours, and should not push the motor too hard... "Very happy with this motor. Mounted this one in a 3kg Extra 300s. Using a TGS 14x7E prop at WOT it pulls 41 amp peak with 3120g of static thrust. 986w using Turnigy 6S 5000 pack. Pulls vertical quite well. Only slightly warm after 9-10 min flight with 3.7v per cell left in the tank!" Edited By MattyB on 21/08/2015 00:43:19 Quote Link to comment Share on other sites More sharing options...
CJD Posted August 21, 2015 Author Share Posted August 21, 2015 Would like to thank you all for your replies. Colin Quote Link to comment Share on other sites More sharing options...
