Throttle cut on DX7 anyone ?
David Mansfield
Hi Gents
 I have a DX7 for use with aeroplane only. Is there a way in which I can set up a switch to use as a throttle cut like you have for the helis. I have been using the throttle trim to cut and then reverting back to previous setting....
 Any help would be most welcome but please treat me as a novice (I have just moved up from a Futaba Challenger for those okld enough to remeber).
  • 2 months later...
  • 1 month later...
Just took a look.
Go to Prog Mix 6
MIX THRO>THRO
RATE: 0% and -40%
SW: MIX
OFFSET: 0
Now the TOP LEFT SW (MIX/RUDDER D/R) will switch the mix on and off. And act as a throttle cut.
If you still want rudder d/r you will need to put all the dual rates on one switch. I also use this scheme to disable electric motors before picking the plane up after nearly severing my right arm once!
Chris
