Martin Plowright Posted January 3, 2016 Share Posted January 3, 2016 I have a black horse travel air that has been damaged when i moved house. I need to rebuild a couple of wing spars that got crushed. Ive removed the covering but this is the problem. The covering is thicker than solar film and is also sticky. Any ideas as to what this covering is or what i can use.Many thanks Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 4, 2016 Share Posted January 4, 2016 It sounds like self adhesive vinyl that is used on pre-decorated ARTFs. I have only had one model like this. I would use Oracover or similar applied in the normal way. M Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted January 4, 2016 Share Posted January 4, 2016 I agree with Martyn K, the sticky covering on Black Horse models once punctured appears irreparable. I recovered a repaired Super Air with Oracover. Quote Link to comment Share on other sites More sharing options...
Martin Plowright Posted January 4, 2016 Author Share Posted January 4, 2016 The problem i have with oracover is the price. It will cost me 30 quid just to cover it plus the repairs i have to make when i can buy a new set of wings for 45quid. Would i get away with stripping both wings and then use solarfilm to cover the whole lot? Quote Link to comment Share on other sites More sharing options...
KingKade Posted January 4, 2016 Share Posted January 4, 2016 Its a travel air! Not a scale work of art! Surely this is a hack, patch repair with whatever you have and make do!? I go for the 'rat look' hack! K Edited By KingKade on 04/01/2016 21:00:35 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 4, 2016 Share Posted January 4, 2016 Yes sticky back vinyl for patches, covering go's brittle on the sticky back stuff so seen lots of repair jobs. John Quote Link to comment Share on other sites More sharing options...
Levanter Posted January 4, 2016 Share Posted January 4, 2016 Martin I have one too. Not yet flown and out of the box there was a small tear on the underside of the wing. Decided to cut out the affected panel plus a bit to fit a chequer pattern to aid orientation. It was tricky to get the new stuff (whatever it was as it came out of scrap box) but I managed. Not perfect by a long way but does the job. Call it a feature. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted January 4, 2016 Share Posted January 4, 2016 Hobbyking do film very similar to Oracover/Profilm at a fraction of the price. Quote Link to comment Share on other sites More sharing options...
