Ton van Munsteren Posted March 15, 2016 Share Posted March 15, 2016 Some of you have already started the build of my new design the Sonny 1500, which is now the new freeplan in the RCME April 2016. Iam a little late starting this blog with my build pics but here we go. Lets start with the Sonny as it was a freeflight model from Graupner with a wingspan 711 mm Its a start and there are many pics to follow. Cheers Ton Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted March 16, 2016 Author Share Posted March 16, 2016 Some more pickies Some are sort of the same but I think you can never have enough pics. If you think its to much now problem just let me know I will stop posting pics. If not than there is more to come. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 17, 2016 Share Posted March 17, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
GeeW Posted March 18, 2016 Share Posted March 18, 2016 +1 on more please Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted March 18, 2016 Share Posted March 18, 2016 +2, please Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted March 19, 2016 Author Share Posted March 19, 2016 Great here some more pics Thats it for now, so some more later. Cheers Ton Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted March 23, 2016 Author Share Posted March 23, 2016 some more Thats all the pickies I have but two video's to follow Ton Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted March 23, 2016 Author Share Posted March 23, 2016 Ton Quote Link to comment Share on other sites More sharing options...
Conwy Soarer Posted March 23, 2016 Share Posted March 23, 2016 Looking good, love the low tech tow release, not seen that done before! Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted May 18, 2016 Author Share Posted May 18, 2016 Conwy Is there any news on the build project with the Kids, would love to see if there is any progress. Cheers Ton Quote Link to comment Share on other sites More sharing options...
David Humphreys Posted May 18, 2016 Share Posted May 18, 2016 That is such a lovely project. I must admit to be being sorely tempted! David Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted May 22, 2016 Author Share Posted May 22, 2016 David, Tempted when do you start. Cheers Ton Quote Link to comment Share on other sites More sharing options...
jordan hall Posted June 30, 2016 Share Posted June 30, 2016 Ton, i must say you have tempted me too and ive given in, already ordered some balsa wood and hopefully will begin building shortly. This will be my first ever balsa aircraft and balsa scratchbuild so results may vary buts its all a learning curve that must start somewhere Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 2, 2016 Author Share Posted July 2, 2016 Jordan, Thanks for having a go at the Sonny, its not really a difficult model to build and Iam here to answere all your questions if needed. Hoping you will post pics of the build and enjoy your build. Ton Quote Link to comment Share on other sites More sharing options...
jordan hall Posted July 2, 2016 Share Posted July 2, 2016 ton would you be able to tell me whats in the shortkit on rbckits as it may work out easier for me to get it to begin with and just add the spruce, electronics and build/cover it Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 3, 2016 Author Share Posted July 3, 2016 Hi Jordan, Sorry don't know whats in the shortkit, but it should be all the cnc cut parts. Best is to send rbckits an email and keep in mind that they will be open comming week and after that close for a holiday. Here is a pic from a German forum the pic shows the complete kit, hope this helps you to have an idea of whats in the shortkit Here is the link to the German forum **LINK** Ton Quote Link to comment Share on other sites More sharing options...
jordan hall Posted July 9, 2016 Share Posted July 9, 2016 im having a little trouble sourcing 4mm balsa sheets, would 5mm sheets be a suitable replacement for the tail. Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 10, 2016 Author Share Posted July 10, 2016 5mm will make the tail section more heavy, so the model will need more lead in the nose to set the CG right. Quote Link to comment Share on other sites More sharing options...
jordan hall Posted July 10, 2016 Share Posted July 10, 2016 ok ton thanks thats perfect and one final question before everything is ordered and paid for is what battery was used ? was it a reciever battery or a lipo with a bec and what size ? Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 10, 2016 Author Share Posted July 10, 2016 Iam using an nicad reciever battery when Iam correct a 700ma, I can take a pic if you like. Ton Quote Link to comment Share on other sites More sharing options...
jordan hall Posted July 10, 2016 Share Posted July 10, 2016 if you would that would be a great help thanks Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 10, 2016 Author Share Posted July 10, 2016 Here is the pic of the batt , but Iam not sure if it will stay in, because I want to make a towrelease system in the nose. For that I need to switch to a flat batt. Ton Quote Link to comment Share on other sites More sharing options...
jordan hall Posted July 10, 2016 Share Posted July 10, 2016 cheers ton and if its any help heres a simple tow release i built before for a foam glider which consists of 2 bits of ply, a bit of wire and a servo which works really well go to 26mins and 26seconds in Jordan Quote Link to comment Share on other sites More sharing options...
jordan hall Posted July 15, 2016 Share Posted July 15, 2016 today both the electronics and the balsa landed so the build process has begun, as of now only the tail is cut and shall be glued and covered tomorrow after sanding, loving this balsa stuff at the moment. Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 16, 2016 Author Share Posted July 16, 2016 Good to see the build has started and its looking great. And great to know you like the balsa stuff. Looking forward to more pics. Ton Quote Link to comment Share on other sites More sharing options...
