David Hall 9 Posted April 7, 2016 Share Posted April 7, 2016 I'm finally getting round to starting this kit. The description says that it needs four or six 9g servos, but the slot for the elevator servo is bigger than that for the rudder. It is 30mm long, the 23mm 9g servo just falls through. I guess that it could be a good idea to use a heavier servo on the elevator, but what size servo slots into a 30mm space? There's not many servo adverts that give the size of the mounting slot.... Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 7, 2016 Share Posted April 7, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
David Hall 9 Posted April 7, 2016 Author Share Posted April 7, 2016 Good to come across a happy buyer, Percy. what size slot would the midi size fit? Quote Link to comment Share on other sites More sharing options...
Depron Daz Posted April 7, 2016 Share Posted April 7, 2016 Make a new servo plate to fit the 9g servo and either screw or glue over the one that's already there? I fitted 9g ones to every thing in my Phoenix. Cannot remember if the elevator hole was bigger though???? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 7, 2016 Share Posted April 7, 2016 Have a browse on Hobby King for a servo it gives dimensions, may be close to a 14 gramme one. John Quote Link to comment Share on other sites More sharing options...
Bernard Alan-Brown Posted February 26, 2017 Share Posted February 26, 2017 The problem with this model is that there is limited clearance between the Servo mounting board and the inside edge of the Fuselage, 15 mm. most servos don't are outside this dimension between the servo mounting surface and the inner rim ofFuselage. I have that problem right now and non of the servo specs have that dimension so I'm stuck. Quote Link to comment Share on other sites More sharing options...
TigerOC Posted February 26, 2017 Share Posted February 26, 2017 Just looking at mine the Hextronik HXT900 from HK would fit. Rob Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 26, 2017 Share Posted February 26, 2017 Was same on mine Bernard, the servo horns rubbed the fuzz, alter the mount and do it better, here's mine. John Quote Link to comment Share on other sites More sharing options...
Bernard Alan-Brown Posted February 27, 2017 Share Posted February 27, 2017 That is a genius Idea, simple I feel stupid for not spotting that option myself !Many thanks. Quote Link to comment Share on other sites More sharing options...
Wihtgar Posted February 28, 2017 Share Posted February 28, 2017 I've got a HS-85MG which fits the larger slot in mine. Not sure about the fuse aperture clearance though but it can be trimmed easily without losing too much strength. Quote Link to comment Share on other sites More sharing options...
