Servo choice for Phoenix 2000 elevator.
David Hall 9
I'm finally getting round to starting this kit. The description says that it needs four or six 9g servos, but the slot for the elevator servo is bigger than that for the rudder. It is 30mm long, the 23mm 9g servo just falls through.
I guess that it could be a good idea to use a heavier servo on the elevator, but what size servo slots into a 30mm space? There's not many servo adverts that give the size of the mounting slot....
  • 10 months later...
The problem with this model is that there is limited clearance between the Servo mounting board and the inside edge of the Fuselage, 15 mm. most servos don't are outside this dimension between the servo mounting surface and the inner rim ofFuselage.
I have that problem right now and non of the servo specs have that dimension so I'm stuck.
