Simon Chaddock Posted June 7, 2016 Share Posted June 7, 2016 As some may know I have a penchant for building electric powered planes that fly for a long time. With the current brilliant weather (warm, dry and little wind) in the NW of the UK I have the opportunity to fly a lot. Two days ago it was the turn of the Depron 40" Super Cub. With its 'operational' wing struts it can safely carry a lot of weight so I fitted an 1800mAh 2s in place of its normal 1000mAh 2s. Launch 10:13 am Land 11.14 am. 61 minutes! The battery needed 1246 mAh to fully recharge so using the full 1800 would give the Super Cub a duration of 88 minutes! This morning still brilliant so out with the Depron 40" Light Weight Tractor. Light (7.8 oz) fully aerobatic and fun to fly but not really that 'nice' as it is has only marginal stability in all directions! However it needs little power to maintain height so fully charge its tiny 850 mAh 3s. Launch 9:11 am Land 10 :14 am 63 minutes of quite high concentration! Power on all the time except for the glide approach and landing. The battery was showing 3.68V per cell so it had used most of its 850 mah hours but it was not at the LVC. Next will be an EDF so the flight will be no more than a few minutes! Quote Link to comment Share on other sites More sharing options...
Chris-J Posted June 7, 2016 Share Posted June 7, 2016 Not boring at all - as a glider guider and slope enthusiast I would be well pleased with those flight times although I must admit that slope lift, for me, is best when it's marginal.😉 Quote Link to comment Share on other sites More sharing options...
onetenor Posted June 7, 2016 Share Posted June 7, 2016 Not boring to me sir. Well done Quote Link to comment Share on other sites More sharing options...
trebor Posted June 7, 2016 Share Posted June 7, 2016 I hope you could sit down, my old pins would start hurting. Quote Link to comment Share on other sites More sharing options...
Darrell Woodward Posted June 7, 2016 Share Posted June 7, 2016 Posted by trebor on 07/06/2016 18:54:29: I hope you could sit down, my old pins would start hurting. I'm gonna add that to my checklist, tis far safer than dangling legs over a cliff (when I get air-born again) Those flight times are incredible Simon. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted June 10, 2016 Author Share Posted June 10, 2016 More boring flying this evening! This was my second ever Depron build. Based on the Wing Dragon layout but increased by 50%. Very docile and easy to fly, in calm conditions it really floats about. With a 3000mAh LiPo and a cruising current of less than 3 A it should be able to fly for an hour and it does! Launched this evening 17.55 hrs Land 19.01 hrs 66 minutes and the battery was still showing 3.67V on each cell. I now have 4 planes that have actually demonstrated hour long powered flights. Quote Link to comment Share on other sites More sharing options...
