Tony Smith 7 Posted June 21, 2016 Share Posted June 21, 2016 Hi, I've seen a couple of threads on the Orangerx RX3S stabiliser from a couple of years back. I fancy trying something like this just for fun, is the Orange one still the one to go for? I notice that Hobby King have a two very similar Turnigy branded units at similar prices. As I say, just really for fun so if there are any alternatives with more features that might be of interest, or customer firmware etc. Will be going into a horrible electric glider in case that's relevant. Thanks, Tony S Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted June 21, 2016 Share Posted June 21, 2016 The only problem with putting in a glider is it will mask the thermals rocking the wings Just make sure you correctly set up the gyro directions correctly, on an aerobatic plane I'd set the elevator gyro in the wrong direction, so when the plane nosed down it compensated by adding down elevator............. Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted June 21, 2016 Author Share Posted June 21, 2016 Good point re thermals, or any other lift. However it needs to be able to switch on/off in flight anyway. Quote Link to comment Share on other sites More sharing options...
Robin Etherton Posted June 21, 2016 Share Posted June 21, 2016 Using this one in my "Notforsale". http://www.hobby-paradise.com/en/product_detail.html?currency=GBP&products_id=3501 Works great. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 21, 2016 Share Posted June 21, 2016 Both Orange versions of Flight Stabiliser are well made and easily setnup following the instructions. Choose the non Rx version if you prefer to fit the unit to your own Rx using male to male plugs/leads Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted June 21, 2016 Author Share Posted June 21, 2016 I'm tempted by the Turnigy one that has different modes remotely activated. That might be great for letting others have a shot of the plane. I use Frsky radio for my planes so the Orange with built in receiver is of limited use (I have a DSMX module but it's not full range). Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted July 7, 2016 Author Share Posted July 7, 2016 Well I picked up the Turnigy model that appears to be a clone of the device also sold as "NX3 Evo". From my tests it seems like the Aux input can not only switch it on/off in flight, but can also vary the gain. Accordingly I've set the transmitter so that one switch enables what they call "Beginner" mode, and another engages "Practice" mode, and in both cases the gain is preset by a pot on the transmitter. First flight tests show that Beginner mode does a pretty good job of levelling the wings as it is supposed to, and also seems to damp the roll response quite a lot. It doesn't seem to change elevator control, making the controls feel a bit out of harmony with well damped roll but pitch still just as sensitive. I haven't tested the other modes yet, need better conditions as the current wind direction seriously limits my landing options. Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted July 7, 2016 Share Posted July 7, 2016 I have used the A 3and A3 Pro extensively inc on slope gliders to good effect. Quote Link to comment Share on other sites More sharing options...
