Hobbyking account issue. Is it a general problem?
I have used HK frequently over several years with no problems. Today I couldn't log in with the reason being given that my password was incorrect. My acount is now blocked/disabled. As I was using my normal password something is not as it should be. Anyone else having problems with their HK acounts? . I wonder if their site has been hacked?
Edited By David Ovenden on 10/07/2016 23:16:53
2 things could be happening here David. The 1st is if someone has hammered your signbin dozens of times wrongly, then thankfully they get locked out.
2nd, the sign in boxes, though they look clear, they are not and have a digit or two already in them.
Click in your sign in boxes, turn them blue, and delete, to clear the info
Then make absolutely sure that you retype the email and password correctly
Do not assume that your device sign in memory is correctly putting the info in
Try this, and report if you will
Thanks to all of you who replied to my question.
Clearing the cache didn't work. However, by contacting the 24hr Chat Line they were able to unblock the account. I still have no idea why the old password wasn't accepted, but at least the problem is solved now and I had really quick service from the Chat Line team
