Martin Ulyatt Posted July 23, 2016 Share Posted July 23, 2016 Hi everyone , sorry for being a pain with questions , i have sc70fs engine and trying to find a spinner for it now it says crank is 5/16 is that the size spinner i need ??? Can anyone shed any light on it please Quote Link to comment Share on other sites More sharing options...
trebor Posted July 23, 2016 Share Posted July 23, 2016 I'm no expert but some of those alloy spinners come with brass bushes to enable different shafts to fit. The thing that got me was Apc 13" props have a thinner hub centre to a 14" and I didn't have room to fit a lock nut with a 14" prop. There are differences in motor prop shaft length as well. Good luck. Quote Link to comment Share on other sites More sharing options...
gangster Posted July 23, 2016 Share Posted July 23, 2016 The spinner diameter is mainly dependant on the diameter of the nose ring on the model. It is quite feasible that you will need to team out the hole in the spinner. You may also need to cut a little away on the spinner to accommodate the prop blades. You should be pleased with the engine I flew a new SC70 fs in a new acrowot that had its maiden flight yesterday the engine performed perfectly and the plane was a dream Don't let the engine snobs tell you you should have bought an engine at twice the price I have never had an SC that was anything short of perfect I have had a few as well of all types and sizes Quote Link to comment Share on other sites More sharing options...
Martin Ulyatt Posted July 23, 2016 Author Share Posted July 23, 2016 So shall i get a 5/16 spinner and see how it fits ? Quote Link to comment Share on other sites More sharing options...
Jon H Posted July 23, 2016 Share Posted July 23, 2016 Hi Martin To keep things simple get one of the Irvine brand spinners. They have a metal backplate with a plastic cone that screws on the front. The worst you might have to do is drill the hole in the backplate to 5/16 of an inch and trim the plastic cone with a knife so it clears the blades. As gangster rightly says the spinner diameter will be dictated by the cowling of your model so check the instructions or just measure the cowl. Quote Link to comment Share on other sites More sharing options...
Martin Ulyatt Posted July 23, 2016 Author Share Posted July 23, 2016 Okay thanks everyone for help Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 23, 2016 Share Posted July 23, 2016 Take a look at the aluminium spinners on page 4 and 5 of IC spinners on model accessories.co.UK Martin. They come with ring spacers and key. Give them a ring Quote Link to comment Share on other sites More sharing options...
gangster Posted July 23, 2016 Share Posted July 23, 2016 Martin not sure what you mean by a 5/16 spinner. The hole in the middle will need to be 5/16 to accomadate the shaft but will as likely as not be smaller than that don't worry about that just drill or ream it to fit the diameter of the backplate is the size quoted by the spinner manufacturer ie 1.5 or two inches. Choose the spinner to got th model. The motor size is irrelevant two types of spinner have been recommended but if you don't want to run to the cost of the aluminium ones the Irvine ones are very good. What model is it for? Quote Link to comment Share on other sites More sharing options...
Martin Ulyatt Posted July 24, 2016 Author Share Posted July 24, 2016 Arh didnt know you could drill hole out , understand now that its so it looks in line with cowl , so much to learn lol , its for acro wot mk2 Quote Link to comment Share on other sites More sharing options...
gangster Posted July 24, 2016 Share Posted July 24, 2016 That's easy then you need a 21/2 (2.5)inch spinner for an acrowot mk 2k Edited By gangster on 24/07/2016 14:26:20 Quote Link to comment Share on other sites More sharing options...
gangster Posted July 24, 2016 Share Posted July 24, 2016 Martin. Have you looked at the RCME review of the acrowot artf. It's on the Ripmax acrowot site. Also be aware of the balance as mentioned in the review Quote Link to comment Share on other sites More sharing options...
