Garry Smith 4 Posted December 26, 2016 Share Posted December 26, 2016 hello all I emailed Futaba's tech support to try to get some help with putting an FRsky DIY hack module into my T7CP as I'm not that gifted in knowing which wires to cut and where to solder connections, I have done a few searches but there doesn't appear to be an idiots video. Interestingly Futaba recommended I use a product called Tactic Anylink http://www.tacticrc.com/anylink/anylink2.html Has anyone used or is using one? Thoughts or comments please And before someone says why don't you just buy a new transmitter, I can't afford it due to a life changing illness. Many thanks Garry Quote Link to comment Share on other sites More sharing options...
MattyB Posted December 26, 2016 Share Posted December 26, 2016 I am amazed they offered any help at all given you were asking to convert their set to a competitor protocol. There are videos out there on the FrSky conversion though - here's a good one (lots of useful help in the video description). This thread on this very forum might also be of use. Edited By MattyB on 26/12/2016 19:51:42 Quote Link to comment Share on other sites More sharing options...
Garry Smith 4 Posted December 26, 2016 Author Share Posted December 26, 2016 Brilliant thank you for the quick reply, makes more sense now when Looking at the FRsky diy module. Thanks Garry Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 28, 2016 Share Posted December 28, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted December 28, 2016 Share Posted December 28, 2016 You need theFr-Sky  " Hack module " for this conversion the YouTube link shows a bodge with the clip in module intended for modulised transmitters. It an easy conversion with only three wires to solder . The trickiest bit is mounting the binding switch LED board to the case and fitting aerial properly to case. Don't bother with the "Any link" it only works with a few indoor models ,possibly "Flyzone" that use a budget futaba system ,probably why it was recommended. Quote Link to comment Share on other sites More sharing options...
MattyB Posted December 28, 2016 Share Posted December 28, 2016 Posted by Percy Verance on 28/12/2016 09:53:24: I think if I'd have been attempting anything like this, I'd have asked Mike Ridley........ Edited By Percy Verance on 28/12/2016 09:53:41 Why? Thousands of us have converted old 35MHz sets with the DIY hack modules; as long as you know where to pick up the PPM stream (easily found online for the vast majority of TXs) it generally takes longer to open up and realise the case than it does to do the soldering. Besides, these sets are pretty much worthless now anyway - if you mangle it and the conversion does not work or doesn't pass a range test nothing has been lost. Quote Link to comment Share on other sites More sharing options...
Garry Smith 4 Posted December 29, 2016 Author Share Posted December 29, 2016 Thanks guys I appreciate the help, one last quick one on reading about the receivers for FRsky, tho bond instructions state the tranny has to be in PPM mode, does this mean that once bound then all the servos have to go through a flight controller as it's set to PPM? Thanks Garry Quote Link to comment Share on other sites More sharing options...
