Prop Drilling using undersized holes
I would like a bit of advice on prop drilling please.
I will soon need to drill a prop for my DLE111. I forgot to order a prop jig, but I already have a jig for a ZDZ50NG.
Both engines are 6 holes on a 29mm diameter with a 10mm centre hole. The only difference is that the ZDZ is 4mm holes and the DLE is 5mm. I am thinking of using the ZDZ prop jig to drill 4mm holes, then without a jig, widen the holes out to 5mm. Will this be accurate enough or do I need to order a proper one?
