Mark Kettle 1 Posted May 18, 2017 Share Posted May 18, 2017 The Dassault - Dornier Alpha Jet is a light attack jet and advanced trainer aircraft co-manufactured by Dassault Aviation of France and Dornier Flugzeugwerke of Germany. Specifically to perform trainer and light attack roles and missions. I'm hoping to make the model from one sheet of depron foam at 5 mm thick, the sheet measures 585 mm by 840 mm which in English means - 23" by 33" . It's took some planning to fit it all on the one sheet but I think I've 'mostly' done it - One Sheet - Above - Alpha Jet side fuselage 30" long, engine pod in grey. Below pattern of the wing fold at 16.5" width so wing span is 33". Below Pattern layout includes :- two wing folds - fuselage side in a fold - fin - tail plane and nose cone lamination's. Pattern is on a sheet of paper to plan the layout, before committing to foam. Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted May 18, 2017 Share Posted May 18, 2017 Did somebody say 'Juan Sheet'!? https://youtu.be/laG8yTNjzFU Edited By Phil Cooke on 18/05/2017 21:44:09 Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted May 18, 2017 Author Share Posted May 18, 2017 That's Plenty... Juan Sheet, does plenty Phil. Edited By Mark Kettle 1 on 18/05/2017 21:45:47 Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted May 18, 2017 Author Share Posted May 18, 2017 I've been practicing on folding depron wings. Used just a 2" wide piece of depron foam. I'm quite pleased with the result. It's took more than one fold but you don't need to see the others. I could place a spar in the section. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted May 19, 2017 Share Posted May 19, 2017 Huh, when I joked that you were going to make one from cardboard, I didn't think you were actually going to do it! Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted May 19, 2017 Author Share Posted May 19, 2017 Only cardboard patterns Andy, depron cut out and glued together. 8 oz in weight, with where the wing is along the body it's almost in balance. Just needs rounding off and tidy up to put some curves in and needs a clear canopy. Edited By Mark Kettle 1 on 19/05/2017 12:15:21 Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted May 19, 2017 Author Share Posted May 19, 2017 Not quite made from one sheet of depron. I needed spars 2 x 30 mm tapering to 10 mm, material for top curve on fuselage canopy area at 35 mm wide and 30 mm underneath on the rear fuselage. The engine pods are from 10 mm wide depron. It's been fun to make, however I've not got time to fit the radio or decoration for the weekend PSSA event. Edited By Mark Kettle 1 on 19/05/2017 12:27:31 Quote Link to comment Share on other sites More sharing options...
