Former Member Posted June 6, 2017 Share Posted June 6, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted June 6, 2017 Share Posted June 6, 2017 Posted by Peter Christy on 06/06/2017 18:03:49: So my question is: Where does on find suitable threadable mild steel in meter or 2/3 meter lengths? -- Pete I'd favour a closed loop for rudders - both light and positive... Quote Link to comment Share on other sites More sharing options...
Stuphedd Posted June 7, 2017 Share Posted June 7, 2017 I have always used welding rod , the straight stuff you use when gas welding , also use the "brass" rod used for brazing , Heat up the ends, hammer them flat , drill small hole in flattened bit , cut 3 cms off Z bend it and thats one end of the closed loop , the other one you want adjustable , Quote Link to comment Share on other sites More sharing options...
onetenor Posted June 7, 2017 Share Posted June 7, 2017 Look here //// http://modelshop.co.uk/Shop/Strip-Shape/Wire/Item/Mild-steel-wire-2-0mm/ITM2170. Buy as long as you need here . BTW mods can't you change the code so we can click right on to read URL s directly .One of the boat forae did it recently it's so much better. PLEASE Quote Link to comment Share on other sites More sharing options...
kevin b Posted June 7, 2017 Share Posted June 7, 2017 Posted by Tom Sharp 2 on 06/06/2017 23:06:09: ooh look, a thread about threads. Pity the poster wasn't called Fred. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 7, 2017 Share Posted June 7, 2017 Posted by onetenor on 07/06/2017 12:24:47: Look here //// http://modelshop.co.uk/Shop/Strip-Shape/Wire/Item/Mild-steel-wire-2-0mm/ITM2170. Buy as long as you need here . BTW mods can't you change the code so we can click right on to read URL s directly .One of the boat forae did it recently it's so much better. PLEASE That's the same site that I linked to in my previous post , and as you pointed out (twice) the wire needs straightening! Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted June 7, 2017 Share Posted June 7, 2017 It doesn't take much work to put a link in if you want one - http://modelshop.co.uk/Shop/Strip-Shape/Wire/Item/Mild-steel-wire-2-0mm/ITM2170 - just highlight the text you want to use, click the 4th icon from the end above and drop the URL in the relevant box... Edited By Martin Harris on 07/06/2017 18:34:14 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 7, 2017 Share Posted June 7, 2017 and please select 'New Window' on the 'Target' tab... Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted June 7, 2017 Share Posted June 7, 2017 Perhaps we should have a poll on that - I prefer to just hit the back arrow after following a link rather than opening (yet) another tab... Quote Link to comment Share on other sites More sharing options...
onetenor Posted June 7, 2017 Share Posted June 7, 2017 Sorry about double post Re the urls I meant click on to read instead of copy paste etc. Quote Link to comment Share on other sites More sharing options...
onetenor Posted June 7, 2017 Share Posted June 7, 2017 One way of straightening the wire is to use an arc/mig welder. Clip one end of the wire in the tool end.The torch.the other into the earth clamp which is held in a vice. Pull on the wire and turn on the welder. The wire should glow red hot while you maintain the tension. Once it is red hot turn off the welder holding the wire straight until it cools. This also anneals the wire making it easier to die the thread onto it. Also various ways here ---- https://www.youtube.com/watch?v=aAsa6CeQW3I Also wire benders and straighteners on the site. Instructables may show more too. Good luck John Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 8, 2017 Share Posted June 8, 2017 Posted by Martin Harris on 07/06/2017 20:27:52: Perhaps we should have a poll on that - I prefer to just hit the back arrow after following a link rather than opening (yet) another tab... you obviously don't get carried away following further links on the page originally linked to Quote Link to comment Share on other sites More sharing options...
