og Posted July 4, 2017 Share Posted July 4, 2017 so i bought this https://hobbyking.com/en_us/hobbykingtm-ss-series-90-100a-esc-opto-only.html problem is it wont work when i connect 7s lipo but its fine with 6s the listing states 2 -7s and also on the esc itself i just get a continuous beep - any thoughts anyone Edited By og on 04/07/2017 13:05:45 Quote Link to comment Share on other sites More sharing options...
Bill_B Posted July 4, 2017 Share Posted July 4, 2017 I'm not sure running it on 7s would be wise despite Hobbyking's claims. There's some info that may be useful on RCGroups HERE (check the link on post #8 too). Edited By Bill_B on 04/07/2017 13:36:35 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 4, 2017 Share Posted July 4, 2017 OG, as daft as it sounds a continuous beep means Low Voltage ! Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted July 4, 2017 Share Posted July 4, 2017 According to the manual provided by HK Problem: After powering up,motor doesn’t work and emits continuous warning tone Reason: Throttle stick not at the bottom Solution: Move the throttle stick to the bottom and calibrate throttle again. The minimum throttle position changes moving from 6 to 7 cells? Quote Link to comment Share on other sites More sharing options...
og Posted July 4, 2017 Author Share Posted July 4, 2017 simon tried it, thought for a minute you were on to something there simon its meant to have a auto cell detector works fine switching between 3,4,5 & 6 cell Edited By og on 04/07/2017 18:11:26 Edited By og on 04/07/2017 18:12:14 Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted July 4, 2017 Share Posted July 4, 2017 Have you tried lowering the trim too? Some escs won't register low throttle unless the trim is lowered right down too..... Quote Link to comment Share on other sites More sharing options...
graeme jones Posted July 4, 2017 Share Posted July 4, 2017 OG - have you tried using the 7 cell pack when it's not fully charged? 6 X 4.2 = 25.2 7 X 3.7 is 25.9 7 X 3.6 = 25.2 If it's a voltage issue there should be a point where the ESC can't tell the difference. Otherwise, is there a faulty cell in the pack of 7? And have you put the throttle TRIM all the way down to trigger the arming system? Graeme PS I had a similar but unrelated problem with a K-Force ESC. Testing different batteries and props I found it wouldn't work with 9 cells, but was fine with 8 or 10. Edited By graeme jones on 04/07/2017 19:47:02 Quote Link to comment Share on other sites More sharing options...
og Posted July 4, 2017 Author Share Posted July 4, 2017 spent all night on this and i am now convinced it is an overvoltage protection thing despite HK claims it is 2 -7s put 8s thro it - same thing ! Quote Link to comment Share on other sites More sharing options...
kc Posted July 5, 2017 Share Posted July 5, 2017 I notice that my programming card for a different ESC ( Turnigy Plush ) has a setting for the number of Lipo cells and it's the same setting as music - marked " Music/Lipo Cells " the instructions say " The 4 LEDs have different meaning for the normal voltage ESC (works with 2S to 6S) or the high voltage Esc ( works with more than 6S ) It also seems to say that Auto detect is up to 4S and 5S ,6S and 7S need differnt setting of the programme card = different LEDs light up. Could it be you need to adjust yours using a programme card? Edited By kc on 05/07/2017 12:02:10 Edited By kc on 05/07/2017 12:06:19 Quote Link to comment Share on other sites More sharing options...
og Posted July 5, 2017 Author Share Posted July 5, 2017 update - HK issuing full refund Quote Link to comment Share on other sites More sharing options...
