Ron Gray Posted August 6, 2017 Share Posted August 6, 2017 Having spent the last couple of years flying leccy and gas powered 'planes I have decided to try my hand at glow power (going back to my roots of some 40 years ago). I've recently read about the uniflow setup for fuel tanks and was wondering what the consensus was about this amongst the learned brethren? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted August 7, 2017 Share Posted August 7, 2017 About a gazillion glow powered models have flow with complete success on a standard clunk tank. I've never used one in anger. However, a uniflow isn't exactly difficult to set up, you just need a second clunk weight. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted August 7, 2017 Share Posted August 7, 2017 Ron, like Nigel says, there is absolutely no need for the uniflow set up unless you have some unique installation, like a heli, and even then, a standard tank does the job Just keep it simple, sealed, and near correct height, and be aware the clunk can rotate from its position at the bottom of the tank, and it is not wedged against the rear tank wall Quote Link to comment Share on other sites More sharing options...
Don Fry Posted August 7, 2017 Share Posted August 7, 2017 Some of the helecopter users, and aerobatic users are fans, for different reasons. But for regular folk, KISS principle applies, put the tank where it should be. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 7, 2017 Author Share Posted August 7, 2017 Thanks for the replies guys. I'll probably setup a 3 pipe tank then if I want to try the uniflow later I can do. I must admit that I can see the advantage of removing the mass of the fuel from the pressure equation plus the reduction in risk of fuel siphoning but, as you guys have pointed out, a correctly positioned tank should suffice. Quote Link to comment Share on other sites More sharing options...
Mr.B. Posted August 7, 2017 Share Posted August 7, 2017 I experimented by converting my FS powered Wots wot from normal 3 line set up to uni flow.......it didn't make any difference. Quote Link to comment Share on other sites More sharing options...
