David Cooke 1 Posted November 26, 2017 Share Posted November 26, 2017 I'm looking for suggestions for 1/16th sheet rudder and elevators please. The model is 24" wingspan so only light loading on the control surfaces. Blenderm tape would do the job but I'm looking for hinges that won't be seen. One idea I read is floppy disk material (with the oxide surface scraped off). Thanks Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 26, 2017 Share Posted November 26, 2017 Use the covering material The old clotheshorse hinge. If usiung film then join by ironing adhesive side to adhesive side. If using some other material with separate adhesive just stick down as shown I have used this with ordinary cloth tape on sontrol liners and film and Solartex on many models. It should work on Litespan too. By using the same as the covering material it will blend in almost invisibly Edited By Peter Miller on 26/11/2017 12:47:35 Quote Link to comment Share on other sites More sharing options...
