ericrw Posted December 26, 2017 Share Posted December 26, 2017 I`ve tried to find the answer to my problem, by searching through the many past threads on this subject but there is so many ! I`m wanting a glue for fixing balsa wing ribs, that has an approx, 3 minute setting time, to ensure the ribs are correctly set. I use CA normally but it does not give me time to reposition. Please advise!! Quote Link to comment Share on other sites More sharing options...
David Tayler Posted December 26, 2017 Share Posted December 26, 2017 Toolstation sell a thick CA adhesive for 99 pence for 20ml. It sets fairly slowly .It works well on balsa and may give you the time you want for repositioning components. It is also foam safe (depron) if used with kicker. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 26, 2017 Share Posted December 26, 2017 I use fast grab aliphatic for wing ribs. Example Quote Link to comment Share on other sites More sharing options...
ChrisB Posted December 26, 2017 Share Posted December 26, 2017 Hi Eric, are you repairing or building new? Gorilla white glue is perfectly good and will dry at room temperature in about 2 hours. I think it’s similar to PVA. Why do you need it to set in 3 minutes? Cheers Chris Quote Link to comment Share on other sites More sharing options...
ericrw Posted December 26, 2017 Author Share Posted December 26, 2017 Hi Chris, It is for a new kit Fokker D V11. I would not want it to be any longer than 3 mins. Just long enough to re-position, if necessary ! Happy New year to you both !! Quote Link to comment Share on other sites More sharing options...
ChrisB Posted December 26, 2017 Share Posted December 26, 2017 Thanks Eric. Cyanosis quick but not repositionable but epoxy is heavy. Personally I’d go for PVA. You’d be amazed how much you can get done even in an hour or two. Happy Xmas. Cheers Chris Quote Link to comment Share on other sites More sharing options...
John Lee Posted December 26, 2017 Share Posted December 26, 2017 Balsa cement will do what you want. Personally I use aliphatic. Quote Link to comment Share on other sites More sharing options...
