alex nicol Posted February 19, 2018 Share Posted February 19, 2018 I have a 12z txt and 3 R5114dps rx's and can't change the freq txt sends but all I get is a single blink of a red led on the rx and no joy can anyone help thanks Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 19, 2018 Share Posted February 19, 2018 There are a few moves involved in this Page 23ish of the manual, **LINK** Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 19, 2018 Share Posted February 19, 2018 Alex, it's a few years since I helped a clubmate match a couple of Rx's to his 12z. IIRC the Tx has 3 types of modulation available - 2 PCM & 1 PPM, he hadn't selected the correct modulation & was having the same problem you're having. You should be able to confirm if this is the problem from Denis's link. Edited By PatMc on 19/02/2018 20:01:24 Quote Link to comment Share on other sites More sharing options...
alex nicol Posted February 19, 2018 Author Share Posted February 19, 2018 Gents, thanks I've got the tx manual and I'm on pcmg3 mode. I'm in the process of going back to basics. receiver number has been entered freq 35mhz, band 76 and mode pcmg3. Tx battery is on charge and new 4.8v 2500mah flight pack is being charged too. once it's all charged up I'll try again. one question is there a master tx reset anywhere Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 19, 2018 Share Posted February 19, 2018 You can Data Reset chunks selected On page 69 of the manual Manufacturers do have such a process holding in buttons at switch on, but it is not common knowledge Quote Link to comment Share on other sites More sharing options...
alex nicol Posted February 20, 2018 Author Share Posted February 20, 2018 Success !!!! , batteries all charged and good, fully extend receiver aerial and lay it across the tx aerial. when you hit the freq change/are you sure? the tx makes a few tring noises. on the 3rd tring switch Rx on and watch the red led, it should have a constant heartbeat flash. once tx stops select end and switch txt to transmit, and it's all good to go. couple of things I don't understand only works if I switch Rx on during third tring. if you only get a single flash from receiver led then it's not going to change. I accept I've fluked a solution but it works. Quote Link to comment Share on other sites More sharing options...
