Ace Posted May 8, 2018 Share Posted May 8, 2018 I love PU glue and am normally very careful not to get any on my hands. You know whats coming next - yes my latex glove sprung a leak and now I have some on my palm Tried thinners, nail varnish remover & Isopropanol with no result - So what will shift it please ???? Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted May 8, 2018 Share Posted May 8, 2018 Time. It'll rub off by itself over a few hours. A few skin cells lost to the dust! Quote Link to comment Share on other sites More sharing options...
Kevin Wilson Posted May 8, 2018 Share Posted May 8, 2018 Gorilla recommend soap, hand cream (moisturiser) and time. They specifically say not to use strong chemicals such as acetone or thinners, but that is probably safety driven advice. I have had limited success with acetone if it hasn't set, but mainly as TWS says, time Quote Link to comment Share on other sites More sharing options...
The Wright Stuff Posted May 8, 2018 Share Posted May 8, 2018 I figured that by the time our fellow forumites had reached a consensus about the best solution, the glue residue would be long gone, anyway! Quote Link to comment Share on other sites More sharing options...
Ace Posted May 8, 2018 Author Share Posted May 8, 2018 Thanks both, but the black grubby mark the diameter of a golfball is refusing to budge. I guess the grease from the skin will eventually lift it but would dearly love a faster solution. Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 8, 2018 Share Posted May 8, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ace Posted May 8, 2018 Author Share Posted May 8, 2018 Thanks David, I thought the dark grubbyness was due to it attracting muck, however looking around there is some evidence of iron darkening PU type glues - you live an learn. Resorted to using one of the foam emery sponges which shifted some - but not all. Guess I will just have to let nature run its course for the remainder. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted May 8, 2018 Share Posted May 8, 2018 Thank you for continuing my education. Are the metal ions getting bonded in, or is some form of chelate forming? An alternative metal source is sodium from salt in sweat.. but most sodium compounds are white, but odd things happen in organic chemistry. Ace, David Mellor is a hard man. If you use very fine wet and dry paper, and some right greasy hand cream, or olive oil, as the wet element, you can reduce the time lag for a second coat of PU to a week. Edit, But as an alternative thought process, for that week you might get away with a burglary. No fingerprint. Edited By Don Fry on 08/05/2018 16:06:01 Quote Link to comment Share on other sites More sharing options...
Martian Posted May 8, 2018 Share Posted May 8, 2018 There is always the same blasting option might hurt though Quote Link to comment Share on other sites More sharing options...
