christopher small Posted August 24, 2008 Share Posted August 24, 2008 I need a 12 volt starter battery 4-6 amps at a reasonable price,where can i get one from?Chris Quote Link to comment Share on other sites More sharing options...
Mr Sam Posted August 24, 2008 Share Posted August 24, 2008 model shops do them also check your local bike shops and motor factors, might get one a little cheaper? Quote Link to comment Share on other sites More sharing options...
christopher small Posted August 24, 2008 Author Share Posted August 24, 2008 thanks mr sam,not many model shops around here,ill keep looking. Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted August 24, 2008 Share Posted August 24, 2008 http://www.component-shop.co.uk/html/lead-acid.htmlTry the above. In COLD weather the bigger the better though. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted August 25, 2008 Share Posted August 25, 2008 The last one I got was from the guy that serviced the Fire and Security system at our office. Identical to the ones you get from MFA. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 25, 2008 Share Posted August 25, 2008 Maplins do a unit containing a 12V 17 Ahr with mains & 12V charger facilities & a compressor & tyre hose all for £ 20 !!!!!!all in a plastic container with ammeter & pressure gauge & it will start your car as well ( built in jump leads).Best buy ever even if you chuck away everything except the battery Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted August 25, 2008 Share Posted August 25, 2008 Chris,The cheapest that I've found is from my LMS, think it was about £11. I've got loads of Motorcycle batteries, but unless you keep them charged they soon become useless and replacenments cost about £35 -£40. The best buy for me was an Oxford Optimate which is an inteligent charger, so when the bikes layed up for any length of time it goes on the Optimate which also maitains the alarm / imobiliser. The starter battery gets a charge every month for a couple of days. It saves replacing the batteries to often.Cheers,Chris. Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted August 25, 2008 Share Posted August 25, 2008 Second time ever, I bought a model boat mag.. www.howesmodels.co.uk advert has 12v 7Amp at £9.99. Carraige would add to that though. Quote Link to comment Share on other sites More sharing options...
christopher small Posted August 25, 2008 Author Share Posted August 25, 2008 Thanks to every one on here for their help,I shall go for either the Kinetic or Sakura,anyone know which is best? I have always used Yuasa in the past but they are about £30.I shall have to check out Myrons car booster -tyre inflater for £20 sounds a handy tool.And thanks Chris your charger sounds ideal for my quad bike,battery is always flat even though it is only 2 years old.Chris Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted August 25, 2008 Share Posted August 25, 2008 I am happy with the Kinetic brand. I have no experience of Sakura Quote Link to comment Share on other sites More sharing options...
christopher small Posted August 25, 2008 Author Share Posted August 25, 2008 That sounds good enough for me,had some cheap torch batteries in the past 6v 4amp completely useless. Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted August 27, 2008 Share Posted August 27, 2008 Got mine from a golf trolley and its brill. Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 28, 2008 Share Posted August 28, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 28, 2008 Share Posted August 28, 2008 Eric Where do you get them from ? As you probably know my main residence is my campervan .It would certainly help me & I didnt realise you could get 500 mAh from such a small area Grumpy Myron Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 28, 2008 Share Posted August 28, 2008 Eric I think I know what you mean about not discharging at night --As to the reference to flashing when charging I'm not too sure about that either ! Seriously I shall check out Maplins tomorrow --Thanks!Grumpy Myron Quote Link to comment Share on other sites More sharing options...
christopher small Posted August 28, 2008 Author Share Posted August 28, 2008 Thanks Eric,I shall have to get me one of those,been thinking about it for a long time,as you say it will maintain the battery power,but not charge it,which seems to be my problem,its losing charge over time.I can soon top it up with my charger,could do with a bigger one for my caravan,to charge it up,will need some kind of controller to control the output though.When my divorce comes through i may have to move out into the caravan ,like Myron. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 29, 2008 Share Posted August 29, 2008 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 29, 2008 Share Posted August 29, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 29, 2008 Share Posted August 29, 2008 Eric My pussy is based next door & has adopted me 'cos I give her something to eat most days PS I only have a small wooden work bench --No silly plastic table you can't stick pins in ! Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 29, 2008 Share Posted August 29, 2008 PS funny how topics change --like the proverbial chinese whisper ? Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted August 30, 2008 Share Posted August 30, 2008 Back on track!Netto will be selling, from Monday, a unit similar to the Maplin one for £20 Quote Link to comment Share on other sites More sharing options...
001 Posted August 31, 2008 Share Posted August 31, 2008 The £19.99 solar panel is sometimes sold by Maplin at £9.99 , I know because I bought one about a year ago. Keeps my flight box topped up in my shed, even in Winter. The same panel is sold by some of the 'novelty' retailers who put free leaflets in magazines at the same price, some searching on the internet might produce results. Quote Link to comment Share on other sites More sharing options...
christopher small Posted August 31, 2008 Author Share Posted August 31, 2008 Hi Richard,thats interesting you say it keeps your flight box topped up in your shed,so they will work on natural light ,not just direct sunlight.My quad bike is in my shed and i am thinking of putting one in there,but thought it wouldn`t be light enough for it.Also thinking of getting a bigger one for my caravan so would it work inside the plastic front window?i shall have to get one and see from Maplins. Quote Link to comment Share on other sites More sharing options...
