Mike Stevens Posted December 18, 2018 Share Posted December 18, 2018 Does any know what the base is of RC Paints please - acrylic or polyurathane as I wish to spray on a clear top coat and had previous attempts react with the paint finish? TIA Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 18, 2018 Share Posted December 18, 2018 I'm not aware of any brand called "RC Paints", so I presume you're talking about paints in general. These days I use matt water-based acrylic paint by Lifecolor, usually applied with an airbrush. With fibreglass models or parts I prime them with Halfords plastic primer from a spray can. When finished I spray the whole thing with Humbrol varnish (which is oil-based) to protect it from the elements. I use matt, satin, or gloss varnish according to what finish I want. The only time I've had a reaction was when I used Solarlac paints (which use cellulose thinner) on top of Humbrol oil paints (which use white spirit type thinner), presumably because of the different solvents. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted December 18, 2018 Share Posted December 18, 2018 Is there a manufactures contact on the tin. An e mail to them? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted December 18, 2018 Share Posted December 18, 2018 These are RC Car Body spray paints for Polycarbonate body shells The clean up solvent is Acetone and may suggest some form of Enamel Paint As you found, these are more difficult to varnish If covering small areas, give light coats of varnish, and time to dry between coats Large areas would need a more stable 1st choice of paint Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted December 18, 2018 Share Posted December 18, 2018 I've used RC Paints sold as matching Oracover. They claim to be fuel resistant but really need some lacquer to protect them..They smell like enamel, I think I used the old Flair Spectra Clear Gloss clear the top to give a reasonable degree of fuel proofing. Not the Spectra 'fuel proofer' 'cos it ain't. The Clear Gloss that they sold was much better. Quote Link to comment Share on other sites More sharing options...
Mike Stevens Posted December 18, 2018 Author Share Posted December 18, 2018 Yes - the ones that match Oracover - ok - several light cover sprays then. Many thanks All. Quote Link to comment Share on other sites More sharing options...
