model recommendation
Tony j
Hi all
I have a fancy to build a war bird . Now I am looking to build from a plan so my preference is that of balsa also that of I.C . I believe that these type of models can be difficult to fly which is why I am asking if anybody out there has one that they might like to recommend as a good one to start with .
many thanks in advance
Tony J
Posted by Tony j on 01/01/2019 23:14:12:
Hi all
Tony J
Nope, they are not difficult, just different. Excessive rates and aggressive flying tend to be the end of most warbirds. Its very much a case of being gentle.
If you are new to the warbird game i suggest an artf first off before you put a kit build model up. The 63 inch seagull P47 is a good first warbird and needs only a 90-100 size engine.
the Brian Taylor spit is a great model but a big build and not the most robust model for club flying. the TN spit is built like a tank but can be a bit porky as cuban rightly points out.
Can you give any further details on the size of model/engine etc you have in mind we can probably advise better
I think my best flying war bird was a gold edition top flight P47, it was about the 60 in. version ,not certain if its still for sale as a kit, easy build all ribs have have tabs to make certain you get a straight wing with the right wash out, you even get jigs for drilling the the holes for the Robart type pin hinges, it builds into a great looking plane and there are loads of good finshes out there to use. It was my last I.C. powered plane and I sold it on, i can still see it coming in to land flying slow with flaps fully down ! I agree having built a few of T.N,s war birds I cannot see how he gets to the flying weight he publishes, but I have one of his 4 fan vulcans and the published weight is correct giving a 15 oz./ft wing loading resulting in an amazing flying plane , dont ask how the others faired.
Take a look at https://www.cambrianplanes.co.uk/ourshop/cat_912071-Complete-Kit-range.html
You will see they make 3 55" span war birds. The spitfire has a reputation of being easy to fly after being quick to build, it may also scratch your itch and cure the craving.
The smaller fun fighters all work well but, if you use a lot of sky whilst flying, you'll need excellent eyesight.
Outerzone has some PDFs of old RCM / Flying Models plans by Dan Reiss, all foam wing, fixed gear, sport type constuction, all about a 70 four stroke size, all using nice friendly thick (ish) semi symmetric wing sections:
Dewoitine D520 - https://outerzone.co.uk/plan_details.asp?ID=2897
BP Defiant - https://outerzone.co.uk/plan_details.asp?ID=5449
MiG 3 - https://outerzone.co.uk/plan_details.asp?ID=7800
Yak 9 - https://outerzone.co.uk/plan_details.asp?ID=1291
Me 109 & Ki-61 Tony - https://outerzone.co.uk/plan_details.asp?ID=9348
It'd be easy enough to fill in a built-up wing structure if needed, or, order a foam wing from billkits or a similar place. I'd be very tempted to pencil in some flaps and use four wing mounted micro servos.
I rather fancy doing the D520 one day.
