Engine Doctor Posted March 10, 2019 Share Posted March 10, 2019 Hi all. Does anyone have piston for a MDS 148 in their bits box they are willing to dispose of ? or a smashed /crashed example with good piston etc they would sell . Please PM me if you can help . Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted April 6, 2019 Author Share Posted April 6, 2019 I'm still looking for a piston for the MDS 148 . Quote Link to comment Share on other sites More sharing options...
jeff2wings Posted April 6, 2019 Share Posted April 6, 2019 So what happened to the original one to need a replacement ?I did a rebuild on one recently ,got the ring from gaviscool on e-bay Btw are you still in need of a Merco crankcase ? Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted April 8, 2019 Author Share Posted April 8, 2019 Engine came in job lot and looked and felt ok . A quick check revealed that about 1 cm of the circumference of the piston above the ring is missing. Ring appears ok ? Yes still looking for a cheap c/case for a 49 . Regards Quote Link to comment Share on other sites More sharing options...
John Duncker Posted April 10, 2019 Share Posted April 10, 2019 Posted by jeff2wings on 06/04/2019 19:56:12: So what happened to the original one to need a replacement ?I did a rebuild on one recently ,got the ring from gaviscool on e-bay Btw are you still in need of a Merco crankcase ? I don't know if you will want to fly the 148. I used a 148 in a 3D model flying the snot out of it for several years. Your 148 has the early carb which is known to have a poor mid range. The carb machined from bar stock with a better mid range. Ripmax gave me the new model carb on request. Once the engine was run in and the carb slow running needle was adjusted it was an extremely reliable engine. NB The slow running needle is very sensitive and needs to be adjusted in tiny steps. Quote Link to comment Share on other sites More sharing options...
jeff2wings Posted April 14, 2019 Share Posted April 14, 2019 John,I think the issues with MDS carbs are legendary,so my one now sports an OPS slide carb with accelerator pump. ED,sorry to say the Merco case is for a 61,as for the MDS if all else fails,most likely could make one fore you ? Quote Link to comment Share on other sites More sharing options...
will -0 Posted May 7, 2019 Share Posted May 7, 2019 Hi, I think there's a piston for sale EsAAOSw0VBch43B">here: EsAAOSw0VBch43B">https://www.ebay.co.uk/itm/UNUSED-MDS-148-2-STROKE-NITRO-GLOW-RC-PLANE-ENGINE-2-STROKE/273835523845?hash=item3fc1de7f05:gEsAAOSw0VBch43B HTH Quote Link to comment Share on other sites More sharing options...
