David Hall 9 Posted March 20, 2019 Share Posted March 20, 2019 My Blejzyk Mefisto has a 30mm spinner and a generic 10x6 prop. This is pretty much the same as my other 2m glider, the Sigma. I think that the spinner/prop combination is very bulky (in aerodynamic terms). Can anyone suggest a spinner that might help make this more streamlined? Quote Link to comment Share on other sites More sharing options...
PatMc Posted March 20, 2019 Share Posted March 20, 2019 Depends what your motor shaft dia is but the white plastic+ali ones here are shorter profile. Quote Link to comment Share on other sites More sharing options...
David Hall 9 Posted March 20, 2019 Author Share Posted March 20, 2019 I'm looking not so much for a more compact spinner, but a narrower installation including the prop. The shaft is 3.17mm. Quote Link to comment Share on other sites More sharing options...
PatMc Posted March 20, 2019 Share Posted March 20, 2019 This offset hinge type spinner might be what you need. You would probably have to change the prop blades if you want the same dia as you have. Actually if you check you might find that with your current prop/spinner assembly the prop is greater than 9" when the blades are extended. Quote Link to comment Share on other sites More sharing options...
Dickw Posted March 21, 2019 Share Posted March 21, 2019 Hyperflight have a good selection of small spinners of a streamlined type, and also prop blades. Dick Quote Link to comment Share on other sites More sharing options...
David Hall 9 Posted March 21, 2019 Author Share Posted March 21, 2019 Thanks for your suggestions. Those offset versions look to be just the thing... Quote Link to comment Share on other sites More sharing options...
