Making wheels
I made some wheels for a smallish model by sandwiching some thin fibreglass between balsa sheet . I drilled out the centre and inserted a bit of brass tube. I mounted it on some threaded rod and spun it in a drill while sanding it to shape. I made a groove around the rim to take the tyre. I got a length of circular section neoprene sealing strip, cut a suitable length of it, and butt glued it with cyno to make a circular tyre.
Plummet
Hi Russ,
If it can be of any help, I made some wheels for my Vicomte 1916 WW1 type monoplane.
Here are some pics >
I used a 6mm balsa core, some ply for the rims, some small ply roundels to give it some thickness, bits of ABS tubing for the bearings and a neoprene 12mm chord for the tires...
Probably your Gladiator wouldn't need the 'spokes', but the basic idea might be the same.
If you want some construction details & materials, please visit my Vicomte build blog starting page 14 & following.
Cheers
Chris
